Need help!
Need help!
New to the site need help! I just recently installed a new fuel pump and flange on a 2011 xjl 5.0l in February just this month the car died out and threw a code p0627 got a new fuel pump under warranty after installing it I知 not getting the p0627 code but I知 getting a new code for p008b low pressure fuel system pressure-too high I bought a new fuel pressure sensor that is literally right by the fuel flange under the seat and nothing has changed I never got this message with the fuel pump I installed in February what could this issue be thanks for any help
As 12jagmark said are you sure those errors are for the in tank pump?
You might have problems with the gear driven HP fuel pumps mounted up on the passenger side of the engine?
Here is a thread and note the burned connectors. Inspection will tell if you have this issue or not.
Jaguar P0627 Code - Burned ground wire
Need help!
I actually noticed the burned ground and connector when I installed the fuel pump in February I was able to find the correct connector and wire terminals to redo the whole connector so that is all new I found that thread when I was researching the problem the first time I also replaced two of the fuses in the rear seat latch just to make sure there wasn稚 a issue with the fuses
Need help
Ok so I had to pickup the old oem fuel pump because it smelled like gas and fed ex wouldn稚 pick it up I clearly can see the difference in the oem one and the one they gave me as a replacement it is surely a remanufactured fuel pump so I decided to throw the oem fuel pump back in since it still works but it did die out once so I知 not gonna keep it well it痴 not throwing the code p008b or any other code but I have driven it and have seen fuel pressures drop down as far as 230 ish psi but the car didn稚 sputter but once when the pressure was that low so where do I go from here
Need help
clubairth1, since fed ex didn稚 pick up the fuel pump I was able to compare them side by side it痴 the whole fuel pump plastic housing fuel level everything just found out it was a remanufactured one by comparing it the connectors on the oem one even say Germany on it and the other doesn稚 there are more differences
alexx93
07-22-2023 04:23 AM
Johndox10
02-24-2022 10:28 AM
gameover
06-12-2018 04:32 PM
62sunbeam
10-06-2013 10:08 PM
