Need help with misfire. 2015 XJR.
This happens more and more. Note that the seller is in high change is a victim as well. (Well, in this case when no original markings on boxes, the warehouse employer should check and notice when parts have arrived on their stock. So sloppy material sourcing by them)
Every big manufacturer have process against for counterfeith now days.
There are tons of grey market parts. This actually happened to me recently, my valve covers came from a JAGUAR dealership to my independent shop. They had Magneti Marelli stamped on them, but FOMOCO made these for JLR. (unless a new parts supplier stepped in as MM is a legit mfg). They started leaking almost immediately and another shop had to tell me they had these markings on them. The original shop re-did the job at their warrantied expense and got new parts from Jaguar but grey market is a big deal.
In my past experience in factory automation, we had pallets of goods come into port in FACTORY SEALS only to discover after shipping to distributors/customers that they were either empty/stuffed or filled with junk equipment or equipment of similar likeness to get it to pass the weight/dims checks.
I think Bosch can check these for you. Since they offer lifetime replacement on their injectors, I'm pretty sure they are serialized and as such can be cross checked with Bosch for their authenticity. It is a chore tho, so easier to get from authorized source to reduce the risk of fake parts.
#28
Like i wrote earlier:
"However: Here are Bosh instructions how detect genuine parts (but like said: Parts can be swapped from boxes)"
https://www.boschaftermarket.com/xc/en/keysecure
