New rotors old pads?
Received 3,887 Likes
Nedoerr, the general rule of thumb is new rotors, new pads. As long as there are not any score marks in the pads, I would say to put on the new rotors and call it good. Granted, I would say to also go out and get the car up to 60 mph and then do a hard brake or two. This will help wear off any unevenness of the pads and ensure you get a smooth surface to the new rotors.
Nedoerr (08-18-2019)
Received 3,209 Likes
But you should roughen/sand the faces first, either with some medium grit sandpaper and a sanding block or do what I used to do years ago, rub them on a cement floor.
You need to do this so the pads have a "fresh" face to bed with the new rotors, then once the new rotors are fitted go through the bedding in process.
The following 2 users liked this post by OzXFR:
mikebaker3 (08-18-2019),
R1 geomet drilled and slotted. They are generally well reviewed, so I’m taking my first experience with a grain of salt. Perhaps the drilled and slotted feature contributed, not sure. One front was barely out of spec at 0.0035, while the other was at 0.0045. Glad they were under warranty for a year though.
XJsss (08-19-2019)
Diamondrmp
11-12-2013 09:31 AM
