Nicodep : my little XJ modded
#61
Hi,
See my post on my website, for me it's necessary to remove the front bumper :
http://www.nicodep.net/XJArden.htm
#62
Hi,
Thanks. Can you please translate the instructions for wiring the DRL on your website to English? Thanks in advance.
#66
![Smile](https://www.jaguarforums.com/forum/images/icons/icon7.gif)
![](https://cimg3.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/led_drl_1_404629f1a8d6b992d306755e11940e4c56121a08.jpg)
![](https://cimg4.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/led_drl_2_33817e7959edc2bdf22ebec09eba4409d13bae99.jpg)
![](https://cimg5.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/led_drl_3_00d2444aec413be99c32ec6f2c014dbe8de11ac6.jpg)
![](https://cimg6.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/640x480/led_drl_4_58556748a266be656caa068a12bc159df8158840.jpg)
Also, I wanted the solid LED bar look compared to individual LEDs. Nicodep you are correct, no way I could install these lights without removing the bumper completely.
It took me a lot longer since I didn't remove the tires due to not having proper jack stands. I found out that the car is very low to the ground when wedge underneath.
![Icon Headbang](https://www.jaguarforums.com/forum/images/smilies/icon_headbang.gif)
griff831 (09-13-2023)
#67
Thanks. I did similar to you, but could not afford the Arden option, so I purchased a set of Jaguar XF LED DRL's off eBay and modified them to fit the opening. A lot more work, but $500.00 less.
#68
The Hella modules aren't nearly as elegant, but they're $150 and don't require front bumper removal. Ideal daytime output, plus optimal horizontal and vertical light distribution. See post #323
https://www.jaguarforums.com/forum/x...199108/page17/
If you don't want to install additional or replacement lamps, here's another DRL solution:
https://www.jaguarforums.com/forum/x...update-247025/
#69
#70
https://www.jaguarforums.com/forum/xj-x351-53/what-did-you-do-your-x351-today-199108/page17
#71
Thank you! I was thinking about a similar installation from some much cheaper Amazon parts, but I may end up with the Hella option. I am planning to do minimal modification to get the wires through the bumper. I do feel invisible on the road with everyone else having DRLs these days.
