No sound with rear USB movies
I have a 2011 XJ with rear seat entertainment.
When I play a dvd, everything is fine for both front and rear.
When I play an xvid/divx avi movie from a usb plugged into the front center armrest, it plays fine with sound. However, the rear does not have an option to play the same movie from that front USB.
Then I plugged the usb into the rear center armrest, and the video plays but I get no audio through the headset. Is anyone experiencing this.
No it is not common. I have no problem with getting sound from the rear USB port for movies. I wouls suggest trying different movies. But if you get sound from the front you should get sound from the rear. I would see if you can play mp'3 through the rear plug. If you don't get sound then there is probably something wrong with you system. Also, you can try the radio through the rear as well to see if you get sound.
