No start
No start
2012 jag xj 5.0l not supercharged
Buddy changed his coil packs and spark plugs on the pass side , now no start I changed the harness for cam adjustment as they were broken and chaffed solderd them in , still no start , no 5 volt to both sides of cam sensors , no 5 volt to crank sensor , I have tested that no wires are broken on every wire , I tested every ecm fuse , I swapped all the relays under the hood , what else should I test , also car ran fine before changing coil packs and spark plugs on pass side and swapped back in the old coils and spark plugs
