Oil Change questions
#41
Yes I have been digging for a while and heard rumors of an over seas Mobil 1 that would meet the specs but I just found this and it's not real common but it is out there. I ordered 6 quarts for $51 with free postage off EBay too!
Not too bad a price.
Also found it on Amazon for $58/6 quarts and also free shipping.
Walmart on-line also offers it with free shipping included.
#42
So we've got at least 3 options, that meet the 5122 spec, at reasonable price :
Liqui-Moly Special Tec LR 0W-20
Mobil 1 ESP x2 0W20
Motul Specific 5122 (this is what I use)
Motul Specific 5122 on Ebay :
https://www.ebay.com/itm/153797014665?epid=245390835&hash=item23cf043489:g6 kAAOSw3vpeHrQM
Mobil 1 ESP x2 0W20
#43
#44
![Exclamation](https://www.jaguarforums.com/forum/images/icons/icon4.gif)
For all those 'draining' the engine oil by vacuum sucking it out with a pump, a question: what about all the metal particulates and metal wear debris in the bottom of the sump? Engine type or size does not matter. It's called 'draining the oil' for a reason. Perhaps I am being old fashioned?
JM2CW....
JM2CW....
#46
#47
Received 3,209 Likes
JM2CW....
JM2CW....
I've done a lot of research into this question (suck or dump) and at least for the AJ126 and AJ133 Jag engines it makes zero difference, not so sure about the 4.2 V8 but I doubt it would make any difference. The reason is that the sump plug on these later engines is on the side of the sump not the bottom and the bottom of the drain hole is about the same height above the bottom of the sump pan as the oil extraction tube is above the bottom of the sump pan, approx 4 mm in both cases. Also all JRL dealerships have used the suck method for many years now.
AFAICT both methods leave the same amount of old oil in the bottom of the sump but it's so little as to be not worth worrying about.
Like you I used to dump the oil via the sump plug as I assumed that would leave less old oil than the suck method but then I found out otherwise.
So about two years ago I switched to the suck method (on my V6 F-Type) and it is so much quicker, easier and less messy than having to crawl underneath to remove then replace half a squillion undertray bolts and nuts.
kroache (06-18-2021)
#48
#49
Received 3,887 Likes
Na5H, if you are worried about the metal particulate in the bottom, simply run the motor for a few minutes before sucking out the oil. That should stir up most of what you are worried about. Then the big thing is to make sure that the oil is warm so that it sucks out really easy. You get it too cold and it takes forever to suck it out. I learned that one that hard way.
Na5h (06-17-2021)
#50
2)-Mobil Super product lines say that they are synthetic BLENDS, not FULL SYNTHETIC, as specified for these cars.
3)-The common theme in all of these oil threads is being sure it meets JLR specs, ie, M2C925 or 5122. With oil that meets specs available for $40.00 or so for 5 liters, ie, Castrol, Liqui-Moly, or Motul, why use something that doesn't?
Harrosito (06-17-2021)
#51
Ah, ok, I didn't know they changed to 0W20, thanks Enosgl !
I have added in total 1 liter (twice half a liter) the last year (8.000 km) of this stuff and have to buy another can now to have in store for the next filling.
So I'm gonna look for the ones you mentioned now.
One of the Ford specifications I mentioned in my post is the renewed specification of M2C925, which they don't sell anymore, so I'm not really worried, but I prefer the full synthetic anyway, this Mexican stuff I put says Tecnología sintética, but yes, maybe that could mean partly synthetic i guess...
Thanks for the reply, it helps!
#52
Harrosito look up thread a bit.
Mark SF has summarized it neatly;
Mobil 1 ESP x2 0W20
Motul Specific 5122
I would stop looking for the obsolete Ford 925 spec and use the JLR spec of STJLR.5.1.5122.
But the good news we have at least 3 other brands beside Castrol that do meet the spec.
Mobil 1 ESP x2 0W20
Motul Specific 5122
#54
Well that's kind of a fighting question around here!! At least the change interval and brand to use!
I will say the engine takes 7.2 L and I change mine somewhere around the 6K-8K mile mark. First time I am using the Mobil 1 X2 oil. Man is that oil green and very thin.
Also just did it the first time using the factory suck out method as I have always done it from underneath.
But I will say that it was the fastest, cleanest and easiest oil change I have ever done!
Can't believe what Jaguar charges for an oil change seeing how quick and simple it is.
#55
Ok, I only did a refill twice so far, two times 1/5 liter in 8.000 km's in total.
Just have it for one year exactly now, no problems and no complaints, 62.000 km's in total now, bought it with 54.000.
Do you and anyone else have an idea how much oil your car consumes in how many km's?
Just to have an idea about the state of things in there.
#57
Yes, you are being old fashioned.
Na5h (06-17-2021)
#58
#60
Na5h,
If you open your oil filer cap you will see a small diameter tube, almost like a dip-stick tube, inside. That is where you hook up the suction tube. When you pump out the oil it will start to gurgle as the last dregs come out, give it a few more pumps and you're done. I was once shown a sump pan from a trashed 5.0 V8, I reckon that the pump method will leave less than 2oz of old oil in the pan.
wombat
wombat
