Oil Leak??
Received 2,632 Likes
Looks like an easy repair I will just replace the gaskets because this is an expensive part
The amount of salt they use on the roads here is crazy sometimes the roads and cars look white because of all the salt
Understood. That must be one effective way to keep only newer daily driver cars on the road then.
The part number for the seal for the vacuum pump is C2D3771.
There are 2 Torx screws that secure the pump to the engine, so not too hard to replace - BUT you need to drain at least some of the engine oil before removing the pump or it'll pour out.
And look closely at which 2 screws you remove, because the other 2 similar screws hold the cover on the pump. If you take the cover off you'll have to reassemble the pump.
If you do a SEARCH in the forum for the part number or the word vacuum, you'll find previous posts with details including descriptions of the leak.
The following 2 users liked this post by 12jagmark:
JaguarXJL15 (03-11-2024),
lotusespritse (03-11-2024)
Salt are used on roads on here too in wintertime. In fact its even worse: They spread saltwater to the roads to make it stick to the road (and cars)
ACF-50 is quite good stuff for underneath. Check this: https://acf50.co.uk/ Protect brakes and exhaust parts. Dont spray it in closed space or to the hot surfaces.
(hint: warm the bottle before you use it by sinking it warm water bucket for about 30min. It penetrate better when its warm. You can use brush or sponce as well)
Ohh, yes: Protect the floor by carboard of plastic sheet. Its quite slippery stuff and wifey are not extremely happy when it ends inhouse on shoes...
RKX Vacuum Pump Rebuild Seal Kit Compatible with Jaguar and Land Rover 5.0L V8 3.0L V6 LR4 RR (V.2)
Back in my very poor college days, my car was starting to rust like this, so I got a house paint brush and a huge bucket of thick axle grease and painted the entire undercarriage. It actually stopped the rust, and the coating stayed there a long time.
I don't have to worry about rust in Houston, but from everything I have read, these spray on undercoating products aren't great.
No, the ACF-50 penetrates thru the rust and make its magic. (read more from the link)
Its good stuff for the sunroof rails as well. Got rid of all noises when i used this to the rusty bit of sunroof rails. (rust have been stayed out)
Anyway, back to the oil leak.
My wife's 2017 F-Pace started leaking from the vacuum pump about 6 months ago. I bought the seal kit and did the job at the same time I did an oil change. Total time was about 1 hour.
Thinking ahead, and even though they didn't need it, I bought two more kits for the x351's ('12&'18). I did those over the winter (during oil changes), again about an hour...perhaps slightly less when you know what you are doing. Most of the time is consumed cleaning off the crud and removing the under-tray panels.
My only bits of advice, for what is actually a really simple job are;
1. Clean off all the old crap BEFORE you start. It helps stopping crud between the seals....and will help you identify if the fix worked.
2. Don't just use the engine to pump O ring. Take your time and replace all the parts in the kik. (There are videos on-line).
3. Use a mini torque wrench when you put everything back together, the torque settings are critical when you are dealing with just two bolts!
Mini torque wrenches are super cheap...if you only use it once you'll have saved $1200 at the dealer!
wombat
wombat
wombat
wombat
I don't understand # 2
"Don't just use the engine to pump O ring. Take your time and replace all the parts in the kik. (There are videos on-line)."
Sorry,
There is a distinct possibility that way too much gin was involved in the post!
To clarify;
The kit sold by RKX has more than one O ring, in fact one of the is kind of an ice cream cone shape and that's the one that fits between the engine block and the pump. Once you have the pump off the car it's really easy to take the pump apart and replace all the seals supplied in the kit.
The RKX website has 'How to' videos
I hope that makes more sense? Hic
wombat
To clarify;
wombat
JaguarXJL15 (03-16-2024)
I was running on 2 quarts of oil, and lost bank 1 cylinder 4 - I was consuming oil I imagine via a valve cover gasket leak or some blow by. My dad passed away that year and I was too busy to check my oil consistently.
It seized in traffic as I was slowing to a stop. There was no oil pressure light coming on before this happened to me, by the way. I noticed some very light tapping noises on the top end that reminded me of the supercharger rattle, pulled over to check it out and it literally seized then and there.
I dropped in a replacement engine from a junkyard for $14k parts and labor. The only regret I have is not taking the time to source a remanned TAPA engine, it would have saved me maintenance costs in the long run and offered much more drive life.
JaguarXJL15 (04-10-2024)
sunchip
08-28-2023 09:21 PM
