Orginal Brakes
jazzwineman (03-12-2018)
Tom
Actually, for the 380 MM fronts (Supercharged 5.0), are all semi metallic except for EBC and TRW, which are ceramic. It was a p.i.t.a. finding the right pads and rotors, and my son actually WORKS at Rock Auto, as they carry neither. That is how I knew that the TRWs are ceramic, as that is what I ended up going with. Not sure if TRW would have a second pad formulation (non ceramic) for Jag OEM use?
John
John
John
John
I am not sure about your comment on ceramics and perhaps I am misunderstanding it, but at this link you see a number of ceramic pads by Centric, Bosch, Monroe
https://www.rockauto.com/en/catalog/...brake+pad,1684
Tom in Plano
Hi Tom,
I was just saying NONE of those Ceramics listed for fronts fit the larger 380 MM front brakes that come on the Supercharged 5.0. As far as my research has yielded, the ONLY ceramics that DO are TRW or EBC. All of those front ceramics are for N/A 5.0 and supercharged 3.0, which use smaller brakes. Still doesn't answer the source of OEM pads, but I THOUGHT someone had said Pagid were OEM.
John
John
FS[LowerAtlantic]: S Type Sport 17" Orginal Wheel
Chris5751
01-22-2017 12:18 PM
getshawty
06-16-2012 09:29 AM
tbar52
08-25-2007 12:58 PM
