Parking Brake Fault :(
Parked up and pulled up the electronic parking brake today, light came up saying there is a Parking Brake Fault and it can't be applied.
I switched engine on and off, same issue, it goes into Park mode on the dial so it won't move or go anywhere, but the electronic parking brake won't go on, is this a common issue? Has anyone had it before?
Its under warranty still so wondering if it will be covered normally under warranty.
In my experience it is the rear pad adjustment. Try this:
EPB Lamp ON, Incorrect Park Brake Operation
1. Start the engine.
2. Firmly apply and release the footbrake five (5) times.
3. Confirm that the message 'NOT CALIBRATED' or 'APPLY FOOT AND PARK BRAKE' is displayed on the Instrument Cluster message center. This indicates that the parking brake is in calibration mode.
4. Lightly press the footbrake pedal.
5. Apply the parking brake by using the EPB switch.
6. Release the parking brake.
7. Release the footbrake.
8. Confirm that the brake warning lamp is no longer illuminated on the Instrument Cluster and that the 'NOT CALIBRATED' message is no longer displayed in the message center.
9. Apply and release the EPB five (5) times to ensure no error is present
You may need to repeat the footbrake/EPB switch 3 or 4 times.
The following 3 users liked this post by XJsss:
retriever-007 (05-31-2015)
retriever-007 (03-26-2015)
THanks will try it if it happens again
What kind of maintenance needes to be done on the EPB cables? Is the standard brake cleaner/spray you get from car garages enough?
I can understand wear and tear items like a brake pad would not be covered, but this is the electronic parking brake (EPB) module or motor, which is part of the braking system, not really a consumable. I will dig up my warranty details, was just wondering it the EPB is a common warranty issue thats covered by major suppliers.
You have posted in X351 forum for the current 2009 onwards XJ. Your post title refers to a 2017 XE and the text to a "Jag XC". What exactly do you have?
