I bought these way back after getting my SS when I was looking for a dead pedal. I ended up going with the OEM standalone dead pedal (from F-Type) instead as it matched those already on the SS (see post#2 in this thread).
I just took this pick of the package contents... still unopened. Definitely screws in all three pieces.
Reason: more info
I started this thread on 11-11-2014, shortly after I bought the pedal covers that were engraved with "Jaguar" and the Leaper logo. I updated this thread yesterday, 1-31-2017, because during that time the price changed and it appears that the engraving is no longer available due to copyright infringement.
You can go to the vendor's eBay site and ask him if he will engrave them for you. I doubt that he will, but if you don't ask you don't get. He will probably think you're the copyright police trying to trap him.
Grizzly - do you know how far the bear ran into the woods?
Just out of shotgun range...., or to the nearest out house.
A $140 accessory is pocket change for a $100K+ XJR. The road of life is short, so enjoy the ride! Spend it while you have it because you can't take it with you.
But if you want it to be a truly sad day when you reach the end of the road, be sure to take the access codes with you!
Just to give those interested an update, i ordered the pedals with the Jaguar logo from the seller mentioned, carforyou11, and received them today. They look exactly like the ones RoonieQ posted, hardware and everything. They do feel pretty good quality, heavy, solid metal.
Installed mine today. You must be a midget with extra finger joints to put those tiny washers and nuts on the back of the screws! I got some of the washers on. I noted that the brake cover is narrower and longer than the stock pad ergo you need to offset it to the left to prevent hooking it with your right foot when releasing the accelerator. I was surprised to find the accelerator pad and arm is one molded piece of plastic.
i thought that was strange too. the brake is metal, but im sure that is a regulation. i did like how the brake pedal had a little bit of a lip on it on the gas pedal side, so it was less likely to have your foot go under the brake. i was trying to figure out a way to transfer that onto the new pedal, but after having them a few months i havent noticed any issues but i did the same as you said, offset it just a bit. if you take your time, you can actually "adjust" both pedals somewhat to make them more to your liking. just get it right the first time.
side note: I am thrilled our gas pedals arent hinged on the floor like a lot of European cars. i like this feel sooo much better.
Contact the Seller (in China) through Ebay and ask him to make a set for you engraved XJ. If he won't do so, ask him for a blank set with no engraving.
I have a 2017 F-Type S with a manual gear box and was super excited to see that RimmerBros.com had a good deal on the 3 pedal cover set. Just got them in and….they do not fit. I guess US pedals are longer. Who knew? 🤷🏾♂️
Originally Posted by Stuart S
From the Jaguar USA
Accessories catalog: Sport Pedal Covers $149.75
"Made from stainless steel and rubber, the pedal kit fits securely over existing pedals for a contemporary, sporting appearance."
RHD - C2D8416 MSRP: $149.75 available online for less
LHD - C2D8415
NOTE: THERE IS NO FOOTREST/DEAD PEDAL!
"Aluminum pedals kit for the Jaguar XJ8 & XJR (Mina Gallery or R center emblem) 2004-2009 models." $159.00 including the footrest/dead pedal. I'm not sure if they offer pedal covers for 2011-up X351 models.
LAST, BUT NOT LEAST: HERE'S WHAT I DID:
BEFORE
AFTER:
Cost $26.80 for all 3 aluminum/rubber pedal covers engraved with JAGUAR and the Leaper logo, from China and worth the wait! I couldn't believe how nice they were when I opened the package - they exceeded my expectations! I expected junk at that price but got heavy duty aluminum with separate thick rubber backing and all screws, fasteners, and tools needed for DIY installation (except a power drill and bits). It took me less than 30 minutes to install everything. Simply line up the covers over the pedals (you don't have to remove them), drill the holes, and bolt them on to the accelerator and brake pedals. The footrest/dead pedal simply screws through the carpet and into the floor with self-tapping screws. I didn't hit anything underneath.
