Plus sized tires
Received 3,928 Likes
Plus sized tires
Before you all loose your minds, I am not looking to go donk on you. What I am looking to do is to keep the overall tire diameter, but get a little bit wider tires under the car. Looking at the rims, it appears that they are almost too wide for the tires that are on the car (currently have 245/45R19s on front and 275/40R19's on the rear). I would be looking at going say a +1 on the tire width (going to 255's on the front, 285's on the rear). Has anyone done this? Room wise it appears I should be fine. I am looking to get a bit more traction for take offs and as always, get some more braking ability out of the car too. I would be tempted on going to 295's in the rear, but then I would probably also need to step down to say a 35 series tire too. Not even sure if the tires are available in the size(s) I am looking at.
Anyone got any comments?
Location: Mooresville, NC (Race City USA), home of most NASCAR teams.
Wide tires are great on race cars negotiating nice smooth and dry track surfaces, but compromise performance on everyday roads, especially if it rains or snows.
As an alternative you might want to simply change the existing tire sizes for a different brand: i.e.: http://www.etyres.co.uk/news/conti-t...in-17719.html; Also check out other sources of competitive tire tests, i.e. Tire Rack.
Gerard Radimaker
09-13-2015 10:33 AM
