Programming Garage Door Opener
I just acquired a 2016 XJL and am attempting to get the onboard garage door opener to work. Have tried holding the door opener remote close to the rear view mirror and pressing both the car and opener buttons. Car LED flashes fast, but then the garage door does not work when pressing the car button. Also tried this 3 times as noted in owners manual.
Also tried by going to the main garage door opener & pressing the learn button and then pressing the car button within the 30 sec time - car LED flashes fast. Car button still will not open the door.
I'm wondering if the basic problem is one of frequency compatibility - the garage door opener uses a frequency of 390 Mhz - there are no dip switches in the remote.
Does anyone have any advice on how to make the car onboard unit open the door?
TIA, Joe
TIA, Joe
Try step 1 if you have not done so, then the remaining steps.
Process:
Program a Garage Door OpenerVehicle:
2016 Jaguar XJ- For first time training, press and hold the two outer HomeLink® buttons, releasing only when the HomeLink indicator light begins to flash after 20 seconds. (Do not perform this step when training the additional HomeLink buttons.)
- Position the hand-held transmitter 1-3 inches away from the HomeLink surface (usually located on your visor, overhead console, or mirror), keeping the HomeLink indicator light in view.
- Using both hands, simultaneously press and hold both the desired HomeLink button and hand held transmitter button. DO NOT release until the HomeLink indicator light flashes slowly and then rapidly. When the indicator light flashes rapidly, both buttons may be released. (The rapid flashing indicates successful training.)
- Press and hold the trained HomeLink button and observe the indicator light.
- If the indicator light is solid/continuous, training is complete and your device should activate when the HomeLink button is pressed and released.
- If the indicator light blinks rapidly for 2 seconds and then turns a solid/continuous light, proceed with the following training instructions for a rolling code device. A second person may make the following steps quicker and easier. Please use a ladder or other device. Do not stand on your vehicle to perform the next steps.
- At the receiver (motor head unit), locate the “learn” or “smart” button (usually near where the hanging antenna wire is attached to the unit). If there is difficulty locating the training button, reference the device owner’s manual.
- Press and release the “learn” or “smart” button (the name and color of the button may vary by manufacturer). NOTE: Once the button is pressed, there are 30 seconds in which to initiate the next step.
- Return to the vehicle and firmly press and hold the trained HomeLink button for two seconds and release. Repeat the “press/hold/release” sequence up to 3 times to complete the training process.
Just tried Step 1 - but no good luck. Still cannot make the garage door move.
I also tried programming the other 2 buttons just in case something was wrong with button 1 - again, no good luck.
Does anyone know the frequency that the car transmits on? I do know my Lift Master is expecting to receive
on 390 Mhz.
on 390 Mhz.
The homelink remote is a learning remote capable of outputting multiple frequencies and code formats. I assume the transmitter you are learning into it operates the door?
https://support.partner.liftmaster.c...-1480438328227
If you opener is SEC+ you will need to do steps 5-6.
TJ
TJ
I had the same issue with my XJ and in both my homes (one had Genie and the other Liftmaster) I installed the Homelink Repeater Kit and it permanently resolved the communications issue. Do a search on it and it may have several different models, but all should work and they are around $40. the unit will allow you to operate all the garage doors at you home. https://www.youtube.com/watch?v=ICJE...ature=youtu.be
ABrice (01-25-2021)
Yes it's called the Homelink Compatibility Bridge. I have installed several of these and your issue matched what I ran into.
They are pretty cheap too. About $25.
Thanks tjankovs - I did do steps 5 & 6 which fixed the problem. Previously, I had not been doing these steps thinking that if HomeLink had
"learned" the old remote transmitter, that would be enough. Obviously not the case!
I actually programmed all 3 buttons on HomeLink to open the garage door - I have no other need for these. All is good now.
![Question](https://www.jaguarforums.com/forum/images/icons/icon5.gif)
tjankovs, I have had the same problem programming my Liftmasters door opener to the 2016 XJs HomeLink button. You say in step 7 to "Repeat the “press/hold/release” sequence up to 3 times to complete the training process." To clarify: would this be a three-times repeat of steps 6 & 7? Where we press and release the learn button on the motor then the appropriate button in the vehicle?
Thanks tjankovs
TJ
Ken Dreger (08-01-2021)
definitely struggling a bit with this one.
while car is in accessory mode:
- clear the homelink memory
- press and hold mirror button 1 + garage remote control
....no luck...have to do rolling code programming
- press the learn button on garage door (not the garage motor)
- press mirror button 1 (no garage remote control)
- did the cycle 3 times (going to garage door control, pressing learn, coming back to mirror and press/hold mirror button 1)
the thing is, the garage lights will blink 2 (chaimberlain garage door)...so its recognizing something? Am i supposed to be pressing the learn button on the garage motor (versus garage door control)
For the last step #7 you press, hold and release the desired button on the visor three times.
