Random P0101 - Resolved
Received 3,923 Likes
For anyone that may get random P0101 codes, this may help you.
Background: while maintaining driving speed, when going up a very gradual hill and maintaining the gas pedal in the same spot, the check engine light would come on. When the codes were looked at, P0101 (may also get P010B code, P0101 is for Bank A (US driver's side), P010B is for Bank B (US passenger side)).
The fix: In my case, I cleaned the MAF sensors and no real change. I even replaced them one at a time with no change. Even changed the mass air pressure (MAP) sensor. All this had not real effect on the error code. Upon cleaning the throttle body, the error code has been gone and not returned, even when trying to make it come in.
Hopefully this helps someone that fights this problem. If you are thinking that the throttlebody was filthy, it wasn't. The big thing is ensuring you wipe the edge of the butterfly valve, not just the outer wall of the throttlebody.
clubairth1, I cleaned my MAF sensors using the MAF cleaner in a spray can. I had the engine off when I did mine. I made sure to spray down inside, dump out the extra, gently spray some into the sensor to let it sit for 20-30 seconds or so to then dump it out with a final rinse of spraying into the sensor. I never noticed any difference in performance with my car. Granted, my MAF sensors appeared clean before cleaning them.
Thank you - I am being challenged with the same issue on my 2008; P010B sets very occasionally at 70mph and almost at the same place which is a long straight section of road and only in the morning. I have wondered if the autumnal mornings and now cooler air here in central CA is a factor. I have cleaned MAF's and all appeared good. I will clean the throttle body tomorrow.
Thank you!
The following 3 users liked this post by RobGardnerBlack:
jimforrest (uk)
02-28-2019 06:42 PM
