XJ ( X351 ) 2009 - 2019
Rear license plate lights
Old 06-22-2011 | 10:50 AM
gears's Avatar
Originally Posted by 0bs
Try LED Illumination I've used the High Intesity 194 white LEDs for the license plate on my '03 XKR and '04 XJR.They look great! The regular 194 LEDs just were not bright enough. You may have to try the bulbs one way and then turn them around to get them to light as they only flow current in one direction. My question is does anyone know what size fuse style bulb my '02 XJR 100 would take? 42 Drat Designs shows a 39mm and 42 mm available.
I tried their bulbs on my XK for the rear stop, tail and turn signal. I took them out simply because I didn't think they are bright enough. Just my 2 cents.
Old 10-05-2011 | 04:27 PM
Skforza's Avatar
hey guys.
i changed all my lights interior exterior to the white xenon LED
Super Bright LED Car Lights, LED Lights For Cars, LED Bulbs, HID Bulbs, HID Conversion Kits and Car Accessories best site very very bright and take the covers becareful as there made of very cheap plastic they snap
Old 10-05-2011 | 10:56 PM
barryf43's Avatar
Originally Posted by gears
I am getting my LED strip in front to illuminate at all times. NOT DLR but just the strips. I posted the hack of "how" somewhere here.
Gears, can you point me to where you posted the hack? I just saw a 2012 XF, which now has the same headlight unit as the XJ. It had just the LED strip on, and it looked awesome! However, my dealer said they can't do that on the XJ.
Old 10-06-2011 | 12:10 AM
Brutal's Avatar
With all the LED's in use, lightbulb checking functions are soon the be unneccessary as they LED's last, well, virtually forever.
well, NO, we replace alot of rear tailights especially the XF for burned/inop LEDs, not all LEDs, but a few here and there.
Old 10-06-2011 | 07:25 PM
Diablo's Avatar
I just saw a 2012XF, which now has the same headlight unit as the XJ. It had just the LED strip on, and it looked awesome! However, my dealer said they can't do that on the XJ
I literally just saw 2012 XF also (just got back from dealer for 1st year service); 2012 XF's LED strip is much brighter than our slightly pathetic "Signature Lights" because they are actually DLRs. I asked service rep about activating DLR on my car - they would do it but advised me XJ's DLR means that the lights are turned on at start-up. I realize there is a hack to turn on just the strip, but the LEDs are so dim that the effect is neglible during the day - looks kind of wimpy
splatter88 (05-03-2014)
Old 11-19-2012 | 09:34 PM
jaser35x's Avatar
Originally Posted by Skforza
hey guys.
Can you tell me how you did the LED swap on the interior overhead (front)? Do you have to remove the entire plastic assembly and get the lights from the back? I was open to open the clear lense for the three lights however unable to actually pull them out, really tight up there and ended up pushing one back up into the assembly...... Thanks!!!!!
Old 02-12-2013 | 10:02 AM
shula's Avatar
Default Rear License plate light removal?
Can anyone tell me how to remove the lens so I can replace the light bulbs for the real license plate? Don't want to break the lens .. Jaguar X-Type, 2.5, 2003 year Model. Thanks
  #28
Old 02-12-2013 | 10:31 AM
another_geek's Avatar
You'll probably have better response by posting this in the x-type section
Old 06-30-2015 | 02:04 AM
ramandanu's Avatar
I finally ordered them all thanks to another_geek. i used autolumination.com because they had more proprietary circuitry and also had heatsinks which I thought were good. Excited to see how it turns out.
BTW I also changed the door puddle lights to the Jaguar projector lights it looks really cool
  #30
Old 06-30-2015 | 03:48 AM
polarisnavyxj's Avatar
Default Can someone post a final. accurate LED parts list
from one store with the correct sizes and colors so the rest of us won't have to do the same experimentation as you.
Theres too much random info here.
We need one concise final parts list please.
  #31
Old 06-30-2015 | 08:19 PM
ramandanu's Avatar
If mine goes well I will post full details. I ordered from autolumination since it was cheaper and they were running sale on the 194's (single CREE). Once I install I will post parts and if it worked for me for autolumination.com...
  #32
Old 07-01-2015 | 05:06 AM
Nice
  #33
Old 07-07-2015 | 01:45 AM
ramandanu's Avatar
Ok. I need help. I got my order in, but a few things I need help, so please help me!!!!
1. The rear footwells seems to be 31 mm and not 36mm. I measured the bulb. In any case they sent me the wrong bulb so I need new 36 mm however I think its 31mm.
2. I cannot seem to get the license plate light to pop off, i think I may have damanged the bumper a bit. it seems to come with it... can someone please help me with how to on that? it doesn't look like it pops off...
3. The rear trunk light I took the original light off to measure again but it wouldn't go on anymore..maybe i blew a fuse?
4. Mirror bulbs, I cannot figure out how to get them out, same goes for rear interior lights. I don't want to damage anything so please help me
BTW the single CREE with cover bulb from superlumination is perfect for footwells just the right amount of white light.
Thanks in advance
Ram
  #34
Old 07-07-2015 | 02:36 PM
ramandanu's Avatar
Ok I figured out the rear interior lights. Still need help on how to remove
1. puddle lights
2. front interior lights
3. rear license plate lights (they seem to be not pryable at all)
4. Vanity mirror lights(two in the rear)
Can someone atleast give me some direction
  #35
Old 07-07-2015 | 04:01 PM
haz783's Avatar
Angry
Hi Ramandanu
the licence plate light is actually REALLY difficult
i couldnt do it
ended up tearing the light off
so now ive got one light missing!
  #36
Old 07-07-2015 | 04:24 PM
XJsss's Avatar
To get at the license plate bulb you remove the lamp assembly by inserting a small screwdriver (the Green line in the drawing) and have to catch the tab (circled in red) and ease out the assembly by prying it out of the bumper, The tab is on the right side of the bulb assembly where there is a Small opening. Hope this explains it.
Attached Thumbnails Rear license plate lights-license-plate-light-removal.png
  #37
Old 07-08-2015 | 02:44 AM
ramandanu's Avatar
Thanks. I tried again today but maybe I jammed it already. I plan to take it to the dealer tomorrow to get some help.
I have done a ton of these though.. .. not sure what went wrong.
  #38
Old 07-08-2015 | 02:22 PM
ramandanu's Avatar
Ok. I took it to the dealer this morning and XJsss you are right it has a catch tab, which is tricky to remove. Finally got it all done including the front bulbs which seems to have four tabs.
I will post pictures and part details on what I used later this week.
  #39
Old 07-09-2015 | 01:47 AM
ramandanu's Avatar
front footwells - 194/168 bulbs, 1 per well
front overhead lights - 3 x 194/168 ( there are two tabs in the front and two on the sides, you have to sort of nudge them out)
rear footwells -- 36mm festoon bulbs, 1 per well
rear overhead lights - 2 x 194/168
rear license plate - 2 x 194/168
Trunk - 41mm festoon bulb
So using another_geek's list. here is the parts list from
superlumination.com
Note: My front foot well and license plates use a single CREE since I wanted the ambience but if you want bright bright you can use the SMT Tower
Front footwell: I used | 2 | T10 Wedge ($2.99 each)
> > > > Item # Cree Xbd With Cover | Color: Super White - Dint want to put too many LED's to heat up the plastic.
Rear Foot well - Remmeber you would have to work the holder a bit since these bulbs have a more sharper edge but it works
> > > > | 2 | Festoon Bulb
> > > > Item # 9 Led | Color: Super White
> > > > | $13.98 USD |
Interior front and back dome lights
> > > > | 5 | T10 Wedge
> > > > Item # SMT Tower | Color: Super White
> > > > Lens: 194
> > > > | $7.96 USD |
Rear license plate - 2 T10 Wedge #CREE xbd with cover
I used the same as the front foot well since I wanted a nice warm white and not too many LED's.
Trunk light - I ended up buying a 41mm pilot from Orielly's local store 9.99, works great.
LaCapitalRue (07-10-2015)
  #40
Old 07-10-2015 | 12:15 AM
ramandanu's Avatar
one small correction. Don't use the single CREE bulb for license plates. They have an angle since its only one LED with cover.
i think you would want the towers for those as well. It will be a bit bright but will light it correctly.
Quick Reply: Rear license plate lights
