Remote trunk close?
I'm certainly glad you documented the step-by-step procedure you followed to do the installation. So, you didn't need to remove the the tailgate/boot close switch? Just disconnecting the manual trunk release is sufficient? The seller's #1 step for installation is to "pull out tail/gate/boot close switch and . . . disconnect green
connector . . .", then remove lower cover panel.
I'll sure give it a try. I'll pretend I'm still in my teens when nothing was impossible to fix on my 1949 Ford, when changing out V-8 engines was just an overnight inconvenience.
THANX
THANX
No the close boot switch stays in the panel, but I did remove the panel and then you unplug it from the back. . The panel is held in by plastic pop in out clips. You have to pull the panel itself out. The ones closest to the trunk lip are a little firmer to pull on and I used a plastic trim removal tool.
My install took a little longer as I have to clean everything before re-installing even if it isn't seen.
I thought I would add a few pictures for reference.
The two clips that face down are the hardest to remove. I removed the outer 4 clips and simply got my hand behind the panel and pushed down.
Panel removed:
Clip locations on panel:
Right side lower clip location on vehicle:
This works great!!!
A few things I also noticed.
It will not close if the vehicle is locked UNLESS you use the chrome bumper button.
The bumper button will close the lip if the vehicle is locked or unlocked.
On the 2016 the remote has to be within 5ft of the trunk/boot for the lid to close (wish there was a fix for this).
Panel removed:
This works great!!!
Use Your Head As An Antenna!
Use your keyfob to repeatedly open and close the trunk, while continuing to move farther away from your car until the keyfob doesn't close the trunk lid. Stop right there and leave the lid open.
Hold the keyfob under your chin, slightly open your mouth and push the button while facing the trunk of your XJ. If the lid closes, repeat the above and see how much farther away you can get before the keyfob doesn't work. Let us know the results.
I'm not joking.
https://driver-safety.wonderhowto.co...range-0139966/
Has anyone else sworn a couple of times after exiting the vehicle and knee hits trunk/boot button and -- there you go, the trunk/boot lid flies open! Makes me crazy! Although, I recently moved from an XJ to an XJL, and it doesn't happen as often. Possibly there's a bit more room/distance from the dash to the driver position. Either that, or I've shrunken more than I thought as I grow older.
Just wondering?.
Just wondering?.
#28
#30
XJsss (08-13-2020)
#31
Ordered August 1, USA delivery August 12. Thirty minute install, because I couldn't disconnect the white connector. Needed to remove the trunk latch (Torx 40) to gain access to white plug release tang. Works as advertised, much better than my last repair job ....
XJsss (08-13-2020)
#32
It seemed that the trickiest part of the install is removing the manual trunk release. So I just left it alone. Pull the 4 back clips down, then pull out the 2 remaining clips at the front of the hard trim (trim removing tool is handy but almost anything will work just pad any painted boot area that you will push against). Once all clips are off there is enough space to see and work from the side or behind the lowered panel. Maybe not 10 minutes, but easily a half hour job, and that's because I double checked all the plugs are snapped in well.
Two quick tips:
1) When reconnecting the green plug to the trunk close button on bottom of boot lid, use one hand to hold the button from getting pushed out as you are pushing in the clip from the inside. Otherwise the button may get pushed out and the 2 small retaining clips can easily fall off.
2) When done close the boot from your remote. If it works, great. If doesn't better to find out now than to accidentally manually close boot and have no way to re-open.
Two quick tips:
#33
#35
#36
I just installed it mine, but it's not closing the trunk when I press the button inside the car, on my remote or silver button on the back of the car. I took everything off and tried again and double checked all the wires.
The button inside the car still opens the trunk as expected and the button on the trunk lid still closes it.
Anything else I should try? I may have gotten a bad unit.
#37
(Still find myself occasionally picking up take-out food, from restaurants that will bring it out to your car)
EDIT.....I just ordered one of these, and should have it late next week, or so. I'll report back, when I have it installed.
#38
#39
A brief history of this "gizmo".
The guy who makes and sells these, Jez, is the same guy who has made the LED upgrade headlight harnesses for me. I originally contacted him about this remote boot-closer after a couple of members on a UK forum (jaginfo) had fitted them and I wondered if it would work on the XJ.
In short, it did . . . and then it didn't . . . . and then it did.
I'm fortunate to live quite close to Jez and he came to see me. After a couple of test units, he got it right and it's this version that you guys are now buying. I can't speak too highly of him.
(He did mention that he was selling a lot the "yanks" when I saw him last weekend! )
XJsss (09-10-2020)
#40
Yes I also want to compliment Jez. When I ordered my trunk opener he told me to wait a bit as he had gotten some bad parts and wanted to verify what was good before he sent mine out.
I appreciate him being honest and waiting a bit for something that works perfect is OK with me!
It's a shame he never did get his version of the LED harness working better. I was ready to buy too. Still have the weak J-blade running lights.
