Replacement security nut for xj
Hello all.
I have had to take a wheel off to sort out a Tyre. And as I put the security nut key in, it wouldn't sit properly, looked inside further and found that it is its not aligning properly as I out the nut key in.
So I'm assuming I need to get a new one, I have the letter code needed, but I need to know where is the best place in the UK to get one. I'm hoping to avoid the dealers.
Xj 351 2014
Rav
Xj 351 2014
Rav
Rav,
Try this: FAQs and https://cs.mcgard.com
I don't know if McGard is the OEM supplier to Jaguar, but you can try and see if the code you have works. Let us know.
If this was helpful, please press at the bottom right.
Stuart
Stuart
Rav,
Stuart
Stuart
McGard is indeed the OE supplier to Jaguar, and they can be contacted either by telephone or e-mail.
Stuart S (01-17-2017)
