XJ ( X351 ) 2009 - 2019
Right head lamp is out
Old 10-04-2021 | 09:34 PM
antdavis1911's Avatar
Default Right head lamp is out
Before I buy another I want to check the fuse. Please let me know where this is located.
car XjL 2011
Old 10-04-2021 | 10:23 PM
Baltobernie's Avatar
Because headlamps are considered an essential safety item, regulatory agencies in most of the developed world require that this circuit be protected by self-healing relays rather than fuses. You could try putting the left headlamp bulb in the right-side assembly to validate its health. If you need a bulb, most manufacturers recommend replacing both sides, for intensity and color issues.
Old 10-05-2021 | 08:20 AM
Thermo's Avatar
antdavis1911, the headlights are powered via a fuse box. The fuse box in your XJ also has a bunch of electronic relays built into it. So, you have much more than just a simple fuse box like in older cars. Both headlights are powered from this modules which has a dual fuse input. So, if you look at the fuse box inside the passenger compartment (the central junction box) and find fuses "BCM-3" and "BCM-4", those are for both headlights. They are each a 40 amp fuse.
Stuart S (10-05-2021)
littledan
03-19-2022 08:12 PM
Golfing8tr
05-08-2020 06:52 PM
stremsjg
12-18-2018 04:59 PM
meirion1
03-01-2016 05:02 PM
hiliters1975
12-25-2011 09:39 AM
Quick Reply: Right head lamp is out
