Right turn high beam on?
Hi guys, I'm from HK and i'm new to this forum. I just brought a 2010 RHD white XJ Supersport but i had 2 questions if anyone can help me out.
1) Every time when i make a right turn with turn signal on the high beam will be on too even when the high beam assist is off. How can i turn it off? 2) If i want to change the whole cluster from mile to km do i need to change the whole cluster?
I had already mod the ECU and pulley. Now the car is in bodykit shop putting on bodykit and 22" wheels. I'll post some pictures about 2 weeks after when it's done. Thanks.
I think the high beam turns on which ever side you make a turn on. I know BMW does this...make a left turn and see if the left side turns on. I dont know if you can disable this.
You can easily change miles to km........using the right side arrows on your steering wheel...move through the menu and you can find the option. I dont know the steps off the top of my head
Wolfy
05-28-2024 08:06 AM
rsa760041
23
09-25-2015 01:33 PM
