Road noise howling
Road noise howling
Are these cars really noisy on the road? I got this howling that sounds like bad wheel bearings, the tires are good quality Michelin Pilots and the bearing is new on the right and the left also looks fairly new. Could it be the driveshaft carrier? The road noise hum/howl is speed dependent, like a train car on rails going faster. I can’t imagine this is normal. But don’t have anything to base it on. The sounds have been there since my purchase. And like I said one wheel bearing is new and brakes new all around. Powerstop cross drilled which I feel I made a mistake purchasing because of the sound they also makes during hard stops. But the other wheel bearing like noise is not letting me enjoy the car.
I have the same problem. Changed the front wheel hubs and had the car checked over .
Nothing found to be at fault .
Two garages suspect tyres . Running on Nankang tyres so not original spec .
Really annoying and ruining the driving experience .
Daimler68
06-18-2011 09:42 AM
