Roof sagging a little
Gents
2011 XJ
Only noticed this the other day. The cross member that has the Transmitter for the wireless headphones (black shiney box ) mine seems to have become detached from the roof area and as such hangs down slightly. There seems to be clips and when pushed upwards the clips kind of grip but as soon as I let go it pops down again. It doesn't make any noise and isn't really noticeable but I would like to reseat it correctly.
Anyone had similar issue? Clips seem difficult to access so any tips most welcome.
C.
2011 XJ
C.
I have attached instructions for the removal of the headlining. You don't need to remove the whole thing but will need to loosen it down by removing a few screws here and there to change the 3 panel clips that you are having a problem with. The panel clips sound like they are broken so need replacing with something similar to these 10PCS JAGUAR WHITE PLASTIC DOOR CARD TRIM PANEL CLIPS | eBay.
Googsy (10-17-2017)
Thank you for your suggestions! I will get to them today. I do not know where the relays mentioned are - but I will find them. I am in age/elevated risk due to Coronavirus so can’t get to a battery supplier. But I cannot jump start it either. I will report back. Thank you all. Alec G.
