Seatbelt bell
Zach, yes it can as I have turned it off in mine. Get into the car and buckle yourself in. Start the car and leave it in Park. After the engine has settled down (come to idle), unbuckle and then rebuckle the seat belt like 10 times quickly (needs to be done in like 10 seconds). This will cause a warning chime to sound. When that happens, the seat belt minder has been turned off. If you want it turned on again, simply repeat the process and the dinger will be turned back on.
Zach12 (02-25-2016)
