Self adjusting music volume
Hi,
I've just purchased a 2010 XJL Portfolio with the B&W sound system, which is AMAZING, however... When your speed drops below 30mph, it gets a little quieter, then when it drops below 10 it gets even quieter still. The car doesn't make much of a noise when it's moving along, so I really don't see the point. If you're listening at a sensible volume to have a conversation at the same time, when you stop at a red light it might as well turn itself off.
Does anybody know how to fix this? On a Ford that I owned previously it was called AVC+ settings, but I can't find details anywhere about the Jaguar.
Alan
Alan
(Edit after having a look at menus) no settings are available to turn this off.
Its speed controlled. I don’t recall seeing it in the menus but have been meaning to look for a menu to turn it off.
speed adaptive volume control isn’t to awesome in my opinion.
ill have a look through my menu screens later and report back if there’s a way to turn it off.
Try turning the volume up to like halfway and then come to a stop. After being fully stopped then pick up your speed to like 60 with a good amount of acceleration. This is when you’re going to notice the volume level increase. It won’t actually change the volume number you’re on just the actual volume you’re hearing in the vehicle, then at a stop again the volume will be a bit quieter. I only really notice it when accelerating pretty good.
now, here’s a quick explanation of why the audio system does this.
at idle you will have no road noise and less engine noise etc.
audio systems that are designed to increase the volume as the vehicle is in motion are turning up the volume to overcome road and engine noise. They are turning the volume up to compensate for other noises that will drown out the sound of the audio and a properly designed system will do this change Very subtly so that you’re mind will not pick up on the change in volume and in theory as the surrounding environment gets louder you will be listening to the same “perceived volume level”
i do car audio and electronics for a living and that’s all I’ve done for 21 years. Most audio systems now would allow you to turn the feature on or off but these radios don’t have a menu to turn it off.
I’ve been trying to hear the described volume change on my car, but I don’t hear it. Ive tried different volumes and speeds. No difference.
sometimes the HD radio station changes back and forth to non-HD source and that causes a change in volume. That can be turned off by turning off the HD radio source completely. Then my volume is constant.
Ok I’m revisiting this thread and also revising my original thoughts about the self adjusting volume.
originally when I purchased the car my volume was dropping at stop lights and increasing when I sped up. The volume change was noticeable and my girlfriend even pointed it out and usually she’s not observant of these kind of things.
when I originally replied to this post I was experiencing a low battery warning when I entered the vehicle but the car started fine so I thought the vehicle had a calibration issue or something
long story short, I replaced my battery, since the replacement battery has been installed I have not had the volume level change described in this post.
it is my official opinion at this point that the vehicle does not have adaptive volume control and my volume was most likely decreasing at stop lights due to less voltage being available to the amplifier.
car5car
09-08-2019 05:58 PM
sandman002
03-01-2011 01:06 PM
