Is this Service manual worth wile?
You really need a wiring diagram to diagnose that sort of issue rather than a service manual.
The attached PDF is the wiring diagram for the luggage compartment lamp on a 2013 XJ. The circuit doesn't look too complicated so you may be able to trace it from the Central Junction Box (see graphic).
C3BP01F pin 4 from the CJB then connector C33-E pin 16.
Randy Mounts (08-27-2019)
Randy Mounts (09-02-2019)
Randy Mounts (09-06-2019)
Randy Mounts (09-10-2019)
sorry to say I never figured it out. i get an alert on the dash when trunk is open. but no light power.. so i did a work around, until i can have it checked at the dealer. i used a tilt switch and a fuse to the battery. work great. but i will someday find the reason the light is not working as it should.
