Is this a (small) quality control issue?
I went to eBay to look at some 2011/12 XJs for sale. I looked at five of them, and I have noticed a common problem looking at their pictures: Inside of the trunk, the carpet on the top left of the opening, just below the weather strip, has been loose and dropped down on ALL of them. For the XJ owners here, does this happen in your car too? I would think at this price point, this car should not present such issue.
Well, I had to go look at mine and, sure enough, the carpet lining was slightly drooping down in that exact spot. There is an overlapping separation of the lining pieces there (and on the other side) and one had just popped out from under the other one, so I just popped it back in. The overlap could definately be larger there, so vibration is probably making the pieces separate over time. The right side was okay.
Received 2,193 Likes
cause there are alot of control modules etc... that are hidden behind the liners that have to be accessed on occassion. trust me when I say its a big improvement over previous yrs and models
I have the previous model and it is exactly the same as you describe. No doubt I'll get round to tidying it up on a warm Spring day. Of course my car is well-used at 8 years old so I'm not so bothered. There are a couple of press-on type fixings, maybe these need to be pressed in a bit harder.
99xk8guy
06-05-2023 06:28 AM
Jaguar Forums Editor
Jaguar Press release
09-03-2015 09:38 AM
