Solving electrical probems and pics of new (to me) 2013 XJL
#61
$750 sounds pretty reasonable to me. I second Lotusprites's YouTube suggestion. Here Here is one featuring your engine. The reviewer does failure analysis of many engines, mostly caused by misuse or neglect. While not applicable to your situation, it may be beneficial to see the complexities involved in removing the valve covers, particularly the one on the right side.
#62
While you are in there, take a look at your coolant parts, stub for the water pump, and anything else that looks aged and replace them, as well as the rear coolant crossover. V6 is easier and more forgiving. I paid $4k all in for my 5.0 valve covers replacement both banks, supercharger removal, coolant tubes installation, but about $1.1k was the injectors that failed after putting the thing back together. OEM injectors are overpriced, if I did it again I would have asked my indy to get a set of 8 from FCPEuro and just swap them at the same time.
#63
As for the supercharger coupler rebuild kit... is this the correct one? It seems to say only for 5.0 l engine and mine is the 3.0 l V6 SS.
This looks better: -
https://powerhouse.uk/
https://powerhouse.uk/supercharger-p...-rebuild-kits/
Is this a correct write up?
https://www.jaguarforums.com/forum/f...-guide-241373/
QP7 (01-17-2024)
#65
And my electrical problems were caused by the oil leak as I am now told the alternator was flooded with oil, from the valve cover gasket leak. I read one poster put in an alternator shield to minimize chances of that happening again, but (if I read that correctly) he also wrapped it in foil which caused one of the nuts to burn out...
Anyway, a new alternator is on the way shorty - will be Delso. Unless anyone has any better suggestions? I may consider rebuilding the OEM unit already in there, but I'm not sure that is even possible when a lot of oil has contaminated it, and also I am not n USA but in a remote location and skill sets there are poor to put it mildly. Delso seems very reasonably priced at $260.
#66
#67
Given I have now read so much about the water pump part numbers and needing the very latest, as I have just ordered the Denso Alternator from Autohaus I just wanted to check, can anyone confirm this is the best and / or latest part number?? (I cant imagine it being as touchy as the water pump issue...).
Denso Alternator
P/N: DE-T2H15686
Denso Alternator
P/N: DE-T2H15686
#68
Beginning to have some faith - Denso Aternator is here (only $259), right part number too - thanks all. Install set for later this week..., plus the new Z23 brake pads. Now I just need the correct supercharger coupling / snout rebuild kit. What do you all recommend for that? And then check to see if the water pump was already replaced, as luckily many of my coolant pipes have been by the dealer in Asia, followed perhaps by decent pressure test.
lotusespritse (01-27-2024)
#69
#71
Kit pn
No, I believe it’s the same.
the hoses crack and wear out over time as well if you have a vacuum actuated supercharger bypass (pre-2014 I think?)
the solid coupler makes some noise as well so I just skipped it.
https://parts.harperjaguar.com/oem-p...r-kit-c2d58056
#72
https://www.wholesalepartsexpress.co...3104-c2d40425/
The main question would be, perhaps like the water pump, is that the most recent part number?
#73
I think you're asking reasonable questions, but there is someone who's job is to answer those (for free I might add). The dealer parts department can help you confirm all of these part numbers with your VIN.
Jaguar doesn't seem to keep revving parts just to rev, keep in mind - this vehicle is OUT of production and had relatively low sales volume to begin with. So only pressing issues push change, especially tool steel changes that might impact how a part is injection molded and shipped to be used in our cooling system. It just probably won't happen.
#74
#75
Thanks for everyone's help, I finally pick her up tomorrow. Apparently many of the coolant pipes have already been replaced by the dealer where the car came from, and we are checking the water pump to see which part number it has on there now. At least now nothing has any seepage, but I will monitor very carefully for obvious reasons. The valve cover gaskets are now done, new alternator (Denso) is in and only left to do is a snout rebuild kit and a new water coolant tank due to faulty sensor. We will see tomorrow how good this chap's work has been... fingers crossed, but he came well recommended. He also replaced the injector seals and oil change, on top of changing the valve cover gaskets. The valve covers themselves were in perfect shape and also there was no carbon build up in the chambers when he had it all open. Thanks all...
#76
OK, I am increasingly convinced there s a deep electrical fault... So I picked her up. All good, It runs very well. Oil burning smell, Likely no big deal - just remnants of oil being burned off after the valve cover gasket change - some long hard drives and the smell is 90%gone. So, likely fine. But then adaptive suspension fault light came back on. This happened before (per this thread) and was an immediate precursor to losing the entire battery and power. Since then I have changed both the alternator and the battery and been told the leaking valve covers shorted the alternator. I do not buy that is the whole story. I have the old alternator and will get it analyzed, but more importantly something is weakening my cars electrical system and no one has yet found it. Another tell? After I plugged in my cell phone charger... 5 minutes later the suspension faults started coming on. (just like last time) LONG WAY TO GO ON THSI X351. And, likely, just another example of parts changing idiocy. Thank God for the forum and people with brains. My best guess, is somewhere deep in the car's system a wire or electrical part of the system is faulty.
Glyn M Ruck
144
06-27-2024 03:08 PM
