Stall On Cold Start When Shifting
5.0SC V8, and 6 speed ZF. 60k miles. I noticed on (very) cold starts, when I shift from D to R, or R to D, the engine RPMs drop quite a bit for a split second and I have once or twice gotten a stall. I have to do quite a bit of this D-R maneuvering getting out of my driveway which is slanted and has too many cars. Everything is perfectly fine once warmed up.
My car got a dealer transmission service 5,000 miles ago, prior to my ownership. Should I service it again to be sure it was done right?
Received 3,929 Likes
silvertones, I have the issue with my car. It seemed to get worse right after a fluid change (installed the ZF Life XXXXX 6 fluid, whatever it is called). I am not sure if it is simply the torque converter not releasing as much as it should or what it is. Something that I have found that I can do is shift into neutral as I get down to a few mph to then roll to a stop and then be gently on the brakes as I shift it back into gear to allow the car to start rolling as it drops into gear. If you find an answer to this, please let me know. My car is not throwing any codes, just has that "I want to keep rolling" attitude on a cold morning like you are experiencing.
Check this:
KeremArsan
05-09-2018 11:56 AM
ArnoldKay
02-28-2017 03:47 AM
