Starting car issues
Starting car issues
Hi guys I a so lucky to be a member with you .
I have 2012 xjl , these days I have problem which is I have to press the egnition bottun 9 to 10 times to start the caafter I changed the smart key battery, even I have to put the key over the egnition butten and press it more tgat 7 time to start the engine . What is the problem please ?
Haytham.zidane (08-28-2021)
2012 XJL Will Not Start
Hey Guys
Had a low battery message. I was not sure if it was the original battery. Swapped battery car started up
2 weeks later the car would not start click click I replaced the starter and the car will not start
I was thinking I replacing the push button start? I replaced once before but I do not remember the circumstances
I was told there might be something in the back middle of the engine to check
Any thoughts
Thanks in advance
Chris .
Any thoughts
Thanks in advance
Chris .
