Steering vibration during parking
Very good chance your wheels are out of true.
I live in NYC and the wheels that come with the car are terrible. Two front went within 2 months and one rear about 4 months later.
I have owned several different luxury cars and these wheels and tires have given me more problems than any other. I am sorry I did not take the tire and wheel warranty but an extra $0995 on the day of picking up the car seemed like a rip off and I never had any wheel or tire problems in 20+ years.
Wow, that's sure low mileage for fronts. Were they wearing unevenly? Have you checked the alignment?
Sounds like you're having bad luck with road hazards. When you hit a pothole and the sidewall is broken and a bubble comes up, your tire is toast. Happened to me regularly with real low profile tires on 20" rims on a Maserati QP I owned--hasn't occurred with the XJ and I've hit a few whoppers.
Jacky Zhong (08-14-2012)
As for the vibration in steering wheel. If turning all the way to the stops, it will give you that vibration and squeekeee sounds. I don't think it's a 'big' problem. Some belt grip spay and then have the dealer check it out later.
But they could be out of line as xjcat said. you see wear on one side of your front tires?
Wanted to chime in on this. I'm new to jag, came from Lexus. I also noticed that there is a vibration during parking. seems to occur when you turn the steering all the way down with the car in drive. If you turn the wheel all the way down with the car in reverse, there's no vibration. Is this normal with the xjl? or with jaguar in general?
During parking or driving? I only get mild vibration during parallel parking
