Subwoofer - Finally going for it
So I finally caved in and have Scott ( Musical Indulgence) in seattle, doing a custom fourth order box with two 8" sundown ..and some plexiglass windows.. Will post picture as he builds the design out... Excited. .. so if you are in seattle area and interested
![](https://cimg1.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1000x910/61emop7j2ql_sl1000__f97d51cc216f683dd608dd819a662db97f500628.jpg)
![](https://cimg2.ibsrv.net/gimg/www.jaguarforums.com-vbulletin/1000x1072/71dairl1ovl_sl1072__3eca00b25d26e029b6a528d92f4adc9e18f36460.jpg)
Uh2 - This doesn't take up a lot of space. The "dias" like structure that goes up in our trunk is pretty much useless unless you are shoving in specific size bags. We at eonly using that space , notice the tape where the limit is setup.
also for the 8". these are not your regular flimsy 8". These are sundown E series V5. See pictures .. these are pretty bad ***..
coxzilla97 (05-31-2016)
I had removed the factory subs and tapped in the line since its fed off the equalizer already so I can still use the sub control in head unit. The opening was used as ports. Altho I'm thinking of asking Scott to make it fourth order since it booms a lot I would like some crisp bass too.
If youa re in Seattle area Scott can probably build more of these for very good price. Takes about two full days of work initially.
I downloaded the service manual detailing how to get access to the speakers.
I have a different thread with pics on this. If you do a sub get an amp with plenty of flexibility with controls. Needs a lot of tuning to get a sweet spot.
jahummer
10-19-2023 08:02 AM
