XJ ( X351 ) 2009 - 2019
Sudden and uncontrolled acceleration
Old 01-19-2016, 07:07 AM
Patrocp's Avatar
Thanks for all the positive feedback everyone. I'll go with the fat footed theory for peace of mind. I love this car too much to let it go. But if the kitty comes alive again I'll have to put her down; will let you know. Thanks!
StypeRowner (01-20-2016)
  #42
Old 01-19-2016, 06:42 PM
Location: Mooresville, NC (Race City USA), home of most NASCAR teams.
I too have noticed the propensity to accidentally step on the accelerator pedal while engaging the brake pedal, and I only wear a 9 1/2 shoe size (U.S.), which is only average.
I think they should have positioned the brake pedal a bit higher relative to the accelerator pedal, and also spaced them a bit further apart. I too have to make a concerted effort to lift my foot higher off the accelerator and then onto the brake further away to avoid accidentally engaging both simultaneously.
  #43
Old 01-19-2016, 07:28 PM
plums's Avatar
Received 2,183 Likes on 1,623 Posts
Originally Posted by JagV8
If you do manage (with brakes fully applied) to get wheel spin or the like, you've faulty brakes that need fixing.
No matter what the engine tries to do the brakes should always stop the car. Worst case the engine revs itself to destruction but still the brakes should stop the car. Faulty brakes if not.
They aren't faulty. It's just the rear wheels overcoming the applied
braking force if the brakes are not fully applied. So long as the fronts
are holding you are fine.
Sometimes this is done deliberately. It's called a brake stand.
Well known to previous generations of street racers in RWD cars.
Some even have devices called line locks installed on the shift lever
to make the process easier to execute. It's a solenoid valve that locks
the front hydraulic circuit after applying the brakes hard. Apply brakes
hard, engage line lock, release brakes, spin rear wheels freely against
unapplied rear brakes while locked front brakes hold the car. The result
is clouds of smoke and warm tires. It can be enhanced by pouring bleach
on the tires and pavement. Some cars have bleach boxes installed. They
squirt bleach on the tires and pavement at the push of a button.
The following 2 users liked this post by plums:
agentorange (03-07-2016), amcdonal86 (01-30-2016)
  #44
Old 01-20-2016, 05:14 AM
JagV8's Avatar
Received 4,534 Likes on 3,943 Posts
I did say fully applied....... (interesting stuff, though).
BTW - anyone who fancies revving hard, stationary but in gear, with brakes applied - don't do it long. You'll heat the gearbox fluid more and more. I'm not by any means sure it can get rid of the heat if you keep it up.
(Someone will describe stall test...)
  #45
Old 01-20-2016, 05:58 AM
plums's Avatar
No argument there.
The main idea is that many drivers have never
actually used the limits of the various systems on
their cars and may report "fully" when in fact they
have come nowhere near that point.
  #46
Old 01-20-2016, 11:33 AM
JagV8's Avatar
Ah... so true!
  #47
Old 01-21-2016, 10:37 AM
Pa.Bill's Avatar
I did not read all the above. But S/C in wiring would not be on my trouble shooting list or way down anyway............... Did you check the cruise control?
  #48
Old 01-30-2016, 01:30 PM
amcdonal86's Avatar
I think the part that makes me think perhaps the problem IS indeed the car is you said you restarted the car and it revved to 5000 RPMs (I'm going off of memory here). If your foot was on the gas instead of the brake, the car wouldn't have started as you must have your foot on the brake to start the car.
  #49
Old 01-30-2016, 01:47 PM
Received 2,263 Likes on 1,845 Posts
Wrong incident, wrong poster.
  #50
Old 01-31-2016, 09:42 AM
JagV8's Avatar
In any case, the actual poster said his pedal stayed down. That's unique but if true would presumably be the cause of high revs. Still, brakes stop the car no matter what.
Jammed by a mat would be the most likely and would explain why the dealer could not reproduce the fault and why it's never been reported since.
  #51
Old 02-02-2016, 09:39 AM
tbird6's Avatar
Yes it's interesting that the new Mustang has line loc as a factory option.
Good way to sell more tires!
jimforrest (uk)
02-28-2019 06:42 PM
Johnken
04-08-2018 10:21 AM
mat32essex
10-03-2015 04:12 PM
Poet
10-02-2015 09:00 AM
Quick Reply: Sudden and uncontrolled acceleration
