Sun Visor Falling Down with bulge on top
Sun Visor Repair or Replacement
Is this something that I would have repaired at dealer or is it best to approach a body repair shop?
Stuart give Tim's Auto Upholstery @ 770 418-1336 at 3568 Buford Hwy,Duluth GA 30096 a try they have done work for me before including headliner on my old XJR, sectioning worn leather on seats. Tims Auto Upholstery | Duluth custom auto upholstery
Stuart S (06-26-2019)
Bumping this back up, same just happened to mine. I am going to attempt to repair the broken plastic housing with some metal reinforcement bars for now. Tests seem to indicate it will work OK, and I'm not spending 500 on a new one of the same design. Design is so bad that these will all eventually break, there's just too much force on the mechanism and it's just held by cheap plastic. This is a very, very easy job, anyone with a T40 screwdriver can remove the visor with 2 screws. Absolutely no need for a body shop to do this.
Same thing happened to mine, found a used replacement on ebay but even that's on its way out. It doesn't stay snugged up against the headliner in the closed position.
From taking apart as much of the thing as possible to see what's going on, what happens is the two plastic edges on the swivel rod "hold" the mechanism in place. With use and age, this can only fail. Once one side of the plastic edge goes, you get the 'won't stay snugged up' issue. When both sides go, you get a totally floppy visor.
Limp Sun Visor replacement
Had the limp visor on my wife's '11 XJL. After trying to locate a used junk yard version I came to the realization that I'd likely not be able to find the exact color and even if I did, how long will it last being that it is used when I get it. I called the local dealer who quoted me over $700! That got my attention, so I gave the dealer my VIN# and got the correct part number which in my case was C2D6286AMN , this part number is for the US version XJL. I did a lot of searching on the internet until I found a German outfit called HandlerParts.com. They claimed that they had the exact item on order and it would take a week before it shipped. For 338.50 Euro ($380.17) including UPS, it seemed like a good deal to me, so I checked all my credit cards before I found that my Costco Citi card does not charge 5% for out of country charges and I ordered it. Well 1 week turned into about 5 weeks, but I just received it yesterday and installed it in 5 minutes. It's a perfect color match and feels solid as it is brand new shipped in factory plastic. I never thought I'd be so happy to pay $380 for a visor, but I didn't even want to drive the car the way it was!
https://handlerparts.com/en
Had the limp visor on my wife's '11 XJL. A... I never thought I'd be so happy to pay $380 for a visor, but I didn't even want to drive the car the way it was!
My visor is beginning to show these same symptoms so it's only a matter of time. Does anybody have a photo of this "mechanism" along with the problematic broken plastic pieces that cannot be repaired? Might it be possible to 3-D print new plastic parts for a repair?
Just curious,
Tom
Just curious,
Tom
in 20 minutes. Now, a year later, that one has drooped along with the passenger side and both now have the tear. I just bought another set of two for $390
and when my wife gets time she will install them. If these fail, I’m going to get the smallest piece of Velcro I can find to keep them from drooping as I really can’t drive safely with them drooping. With these three failures, they have caught up with my three water pump failures, ah yes, the joy of owning a x351
