XJ ( X351 ) 2009 - 2019
Sunroof
Old 07-17-2017 | 11:17 AM
dragonalfa's Avatar
Default Sunroof
when I close the sunroof blind it doesn’t fully close, leaving a small gap. Only noticed last night is this normal?
Old 07-17-2017 | 12:52 PM
TheBoy's Avatar
nope.
Old 07-17-2017 | 02:42 PM
roviw's Avatar
There is a reset procedure for this, I did see it mentioned some years ago either on this forum or the GB one, I think it may be in the handbook but not sure.
Just found this , I did not put my finger in the gap but used something else.
https://www.jagshops.com/jaguar-xj-3...f-shade-issues
Old 07-17-2017 | 03:13 PM
dragonalfa's Avatar
Thanks ... Ill have a look in the handbook then.
wonder if it’s down to my battery as I have had strange things happening these days.
ill get it changed as jag did say it’s 5 years old now.
Old 07-18-2017 | 03:38 PM
roviw's Avatar
If my car is not used for a while I use a battery conditioner, a CTEK, it prolongs the life of the battery, my car is 6 1/2 years old now, fingers crossed all seems well.
Old 07-18-2017 | 04:10 PM
xdave's Avatar
Note with the reset procedure you really do need to hold the forward/close button in for a long time. (Until it has fully opened and closed again before releasing.) I found it quite uncomfortable to hold my hand up for that length of time, but it has always worked on my 2010 X351.
dragonalfa (07-18-2017)
Old 07-18-2017 | 05:05 PM
dragonalfa's Avatar
Thanks, it does tell you the procedure in the handbook
and all back to normal again now.
again many thanks for the help guys
