Sunroof Blind
Sunroof Blind
Whilst closing my sunroof blind it sounded like something snapped and now can't get the blind to close. When I press the close button the motor runs and the roller rolls but the blind doesn't move.
Does anybody have a diagram of the sunroof and blind mechanism so I can get a better idea of how this works. Is there a step by step process to get this repaired. I assume it involves removing the headliner.
I managed to fix the blind. One of the feet had broken so that was replaced. The only issue I now have is the blind is sagging very slightly on the right hand side whilst on the left hand side it is tighter. I have performed the reset procedure but didn't fix this problem. Does anybody have any ideas.
The rear shade open and close but not completely close. This was like that from new.
The front make noise and it is stuck open.
Thanks for your help!
sandro
You need to replace the motor of the sunroof and probably left, right or both feet. Mine needed the left feet and the motor. 1400 euro at the dealership.
I bought the new roof for the same price and got rid of the rust and cracking noise from the sunroof. It was exactly the same price ( 1400 euro ) from the donor car from Florida ( 2014 MY ).
You won't be able to fix that easily as it requires a lot of work ( dealership calculated 9 hours total ) and spare parts.
The following 2 users liked this post by lolshto:
Sandro Felisio (07-13-2018),
xdave (07-11-2018)
So cheap.....
I had exactly the same problem as yours. Same front shade, absolutely same noise.
