Sunroof Shade
#41
It's most likely a battery issue
Hi there. Looking for help. Just purchased a 2012 Jag XJ and I am having the sunroof shade issue stated in this thread. I have read through each one and tried the button reset procedure and even the hand in the shade procedure to no avail. Still a gap! I have chosen to try to ignore it but it is annoying as heck.....any help?!?!?!
I've since sold the xj but the repair for the rear sunshade proofed very expensive. The sunshade is like that because your battery has at some point gone flat. I would suggest that you reset the battery and then try holding down the buttons, perceiver with this, don't try the hand in the sunshade thing, it will proove expensive.
ruizabe (01-09-2017)
#42
#45
#46
Received 2,192 Likes
I have both for sale oem with sliding blocks
casting motor and slide blocks, front $290. Rear $400. Shipped or will both a package deal for both
#47
as you see in the video the problem is on my front shade.
I suppose I need the motor.
My model is 2011, do you need the vin number?
thanks a lot.
Sandro
Phil Davies (03-04-2021)
#48
[QUOTE = Sandro Felisio; 1978392] HOLA,
como ves en el video el problema está en mi persiana.
Supongo que necesito el motor.
Mi modelo es 2011, ¿necesitas el número de vin?
muchas gracias.
Sandro [/ QUOTE]
Buenas tardes, me pasa exactamente lo mismo que lo que se ve en su video con mi cortina delantera, ¿como lo soluciono ?.
Gracias y un saludo,
axtmerce
muchas gracias.
Sandro [/ QUOTE]
axtmerce
#49
May not be related, but just bought a 2012 XJ super sport and the front shade wasn't working as well as the auto folding mirrors.
The drivers mirror seamed loose and wouldn't catch on a detent.
I manually tried folding the mirrors in by holding the two switches down and the passenger side fold in. cycled them a couple times, heard a click on the drivers side and now both not work
as well as the front shade. Coincidence or are they somehow tied together?
