supercharger belt rubbing tensioner
If it was rubbing, you'd see marks on the tensioner and rubber dust all over the place. Is it the same belt that was on there before you did the work?
And to answer your question, yes, it is routed correctly. But from what very little I can see from here, it looks like the belt may be a bit too short, causing the tensioner to rotate counter clockwise (as you look at it from the front), bringing the belt closer to the tensioner body. Also, please repost the pictures you had in the other thread here for easier reference. Thanks.
do belts skrink and contract over time I could see that. Its a velocityAP belt I got when I did the programming and tunning but its probably go 40k miles on that belt. What is the smooth pully that has the marks from the belt on it bc I think id like to swap it out while im in the fixing mood. Everything else is grooved.so why not.
My advice would be to call VAP. With only one picture, minimal info, and unanswered questions, you're at the limit of what you can expect to get out of this thread.
