SuPerCharGer Removal?
The black bracket can be removed but is a real PITA to do. also that vacuum hose can be removed to give an inch of assess to the drain plug see photos of mine an xkr 5l supercharged 2011 car it is same engine as yours .
On reflection this change of the supercharged oil is a must "if you love your car . the oil i took out was not only foul smelling and darkish brown but some of it had evaporated over the years . i put in more than i took out. and with the drin/fill plug you cant put in to much as it just runs out . Me will do this every 3 year from now on will save on and problms that should arise due to old sluggish oil in supercharger
#28
#30
