XJ ( X351 ) 2009 - 2019
SuPerCharGer Removal?
Old 11-23-2019, 04:39 PM
George05's Avatar
Originally Posted by Mike Kuznets
Hi
I'm removing my s.c. for same reason.
question, on the back of the s.c. there is a bracket connected to the s.c. do I disconnect that first or once the s.c. is lifted. It is really hard to get in there.
thanks
The black bracket can be removed but is a real PITA to do. also that vacuum hose can be removed to give an inch of assess to the drain plug see photos of mine an xkr 5l supercharged 2011 car it is same engine as yours .
Old 11-23-2019, 04:43 PM
George05's Avatar
George05's Avatar
with photos
Na5h (10-14-2021)
Old 11-23-2019, 04:56 PM
George05's Avatar
The xkr 5l and xfr and xj 351 ftype and range rover sport and range rover all 5l cars share same engine and fill/drin plug is in same location . no such word as impossible we brits ruled the world
Old 11-23-2019, 05:01 PM
clubairth1's Avatar
Received 2,457 Likes on 1,931 Posts
That was a very good repair but I think when I pull the SC to change the rear water manifold I will change the oil then.
I already have the GM SC oil.
Old 11-23-2019, 05:17 PM
George05's Avatar
On reflection this change of the supercharged oil is a must "if you love your car . the oil i took out was not only foul smelling and darkish brown but some of it had evaporated over the years . i put in more than i took out. and with the drin/fill plug you cant put in to much as it just runs out . Me will do this every 3 year from now on will save on and problms that should arise due to old sluggish oil in supercharger
Old 11-23-2019, 06:00 PM
Mike Kuznets's Avatar
Default 2016 jaguar f-type r supercharger removal
Finally got the supercharger out.
thank you for the help.
I did leave the cowl on. Had a helping hand to get it out
  #28
Old 11-23-2019, 06:19 PM
George05's Avatar
Good job but a lot of work eekkk
Old 02-09-2021, 04:56 PM
onecall's Avatar
Default rear bolts
my jag has been down since june 2009 how did you get to the rear bolts?
  #30
Old 02-11-2021, 02:34 PM
clubairth1's Avatar
Maybe time to let it go and get another car?
  #31
Old 02-11-2021, 02:53 PM
onecall's Avatar
Default I did lol
I purchased a new one when it broke down with a new paint job and wheels so its taking up space in my shop.
Keobakile
XF (X260)
04-04-2023 10:54 AM
rhriczko
11-30-2018 06:13 PM
sanchez
01-10-2016 09:50 AM
The Coupe
02-27-2012 10:43 AM
super_jag
Exterior
04-20-2009 11:31 AM
Quick Reply: SuPerCharGer Removal?
