Suspension Fault Adaptive Dynamics Fault
Hi All,
MY 2016 XJL with 51000 miles.
I have this warning message happening now every time I start the car. Everything was fine until a couple of days ago I had driven the car and parked it with no warnings, went to drive it the next day and the warnings are there, car had just been parked over night no other changes. Has anyone experienced these warnings on their cars? There doesn't seem to be any difference in ride quality or ride height at this point. Any input or ideas about what might have caused this to suddenly occur are appreciated. I am down in Mobile AL at the moment and do not have my code scanner with me, hoping to avoid having to go to the dealer.
Appreciate all help offered. Paul
Received 3,923 Likes
Paul2005, my car was giving me random error codes and mine has suddenly stopped doing it. I did two things that I can think of that may have caused it to stop. The first was putting in a new battery. The problem continued for a week or so after installing the battery. So, not sure if the battery is truely a fix or not. But, my battery was 7 years old and probably needed to be replaced any ways. The other thing that I did was get the tranny fluid changed. My car had gone 100K miles (70K under my ownership and was bought from a dealership) and I figured it was time to get it done. Now, I did get 2 more instances of the fault coming in, but it has since cleared. The only "instance" that I can relate to the light going off was that I was driving down the road and a branch fell on the road directly in front of me. I had no choice but to run the branch over. Ever since then, I have not gotten any error codes. In your case, have you run over something that may have bounced around on the underside of your car? You have 2 sensors under there that monitor the height of the car.
As for what you will feel, you should feel the suspension stiffen up on you and give you a harsher ride than normally. What happens is when this error code comes in, it stops sending an electrical signal to the shocks and causes them to go to maximum stiffness. Other than that, this is all that you will feel.
I once received this code, prior to calibrating my air suspension. I cleared it, calibrated my suspension then cleared the code. It did not come back.
I'd say in general try and clear it and see if it comes back. Not sure how cold it gets in Mobile, but here in the Midwest sometimes these air compressor related problems can start showing around winter time, then get progressively worse.
On that note is there anyone in the Mobile area that has the SDD software and cable? Might make diagnosing this problem simpler.
Thanks for your input
Paul
Hi All,
I think the tool adjusts for variation between the wheel outside edge and the wheel arch edge. I just used a ruler, before I had a deviation of 6mm on one side compared to the other, probably from the last time the dealer busted my drivers wheel delvering the car back to me after warranty work. There are some guides on youtube to calibrate land rover suspension with aftermarket software, it was a similar process.
They shipped me a wheel and tire and I had it installed and sent them the bill. Probably should have had them check the front suspension, it's going in next week to be looked at. My ride is pretty bumpy in Wisconsin once winter peeked its head out (from yesterdays post to today, lol) I inspected my bushings and both front upper control arm bushings are cracked and leaking. I have 49k miles.
To answer your question, I should reconfirm what the distance is from tire to wheel arch.
Nedoerr (11-18-2019)
MaxJ92
08-26-2019 10:03 AM
Mike-Ko
01-22-2019 11:00 AM
Mac Allan
22
04-19-2016 02:09 PM
