XJ ( X351 ) 2009 - 2019
Tail light condensation
Old 11-19-2017, 09:27 AM
Hank Scorpio's Avatar
Default Tail light condensation
Have any of you guys experienced this? It is pretty much through the entire passenger side light, and never goes away. It wasnt there when I bought the car, but when the weather started getting cooler, it appeared and hasnt gone away.
My car is a CPO, but my local dealer said this isnt covered under the CPO (and the booklet I have basically says the same thing). My salesman (from a different Jag dealer) said it really depends on the servicing dealer's relationship with JLR corporate. The old methods of taking out the bulbs and drying the inside with a hair dryer wont work, and I am apprehensive about drilling a hole in the bottom of my tail light. Though if I need a new one, what difference does it make. Aside from pointing a hair dryer at the outside, or putting the tail light in a giant bowl of rice, anyone have any experience or ideas?
Or should I use this as an excuse to get 2016+ tails?
Old 11-19-2017, 11:45 AM
roviw's Avatar
I had a small amount in mine ages ago, nothing as much as yours though. Try actually searching the forum and the UK forum as I am sure it has been mentioned before.
Old 11-19-2017, 11:51 AM
clubairth1's Avatar
Received 2,348 Likes on 1,849 Posts
Is that a slight crack in the plastic in your first picture?
Have you removed the light to inspect it where you can't see?
Old 11-19-2017, 12:03 PM
i searched here, at least the XJ forum, and there was nothing related. I forgot about the UK forum though.
I saw the small possible crack between the signal and the trunk earlier today when going out, but I just saw that larger one now that im looking at the pictures on a big monitor. Good catch. If that is i a crack and not a scratch, thats my answer.
I havent taken the light out yet, I was doing a lot of searching for manuals or step by step, i wasnt sure if the bumper had to come off, but based on what ive seen on the rear of the lights, it doesnt.
Old 11-19-2017, 09:19 PM
Whatever that line is, or was, i cant find it on the light now, at least with a flashlight in the garage. I will check again tomorrow during the day, but now that I know how to take the lights out, im going to give that a shot over the long weekend. Worst case scenario is i start sourcing some 2016+ tails.
Old 11-20-2017, 12:23 AM
rhomanski's Avatar
I remember reading these are LED, are they sealed with just wires hooking up to the assembly or do they have a replaceable LED bulb kind of a thing?
I've considered replacing my incandescents with the LED's that are made like a normal bulb. I have so many spare bulbs though I haven't run out yet.
Old 11-20-2017, 09:54 AM
As far as i can tell, there is just one connector into the housing assembly to power the LEDs. Everything is internal, so there is no bulb to speak of.
Whether the connector on the housing itself comes out, im not sure yet, but even if i did, i dont expect it to be much use since the LED boards will be in there, but ill know for sure this weekend.
Old 11-20-2017, 01:49 PM
rhomanski's Avatar
With regular bulbs the heat from driving at night will eventually dry them out but that will never happen with LED's.
Old 11-20-2017, 03:03 PM
Yeah once that clicked in my head it was a bit of a bummer. I am going to try a couple of low dollar solutions, like drilling a vent hole in the bottom or using desiccate packets, or just pointing a hair dryer at it, but im not really expecting much.
Old 12-02-2017, 09:08 PM
in case anyone else has this issue and is searching the forum, drilling into these to let the water out really doesnt seem like a logical option, unless you have a replacement light available. the potential to drill into something, since you cant see what you are drilling into, is too high.
removing the tail light and basically hitting it with heat seems to be the best solution for now. i used my fireplace (gas) and since that is heating up the entire house, my next option is to try a small space heater. as far as fixing the problem from happening again goes, the lens doesnt seem to be one solid piece of plastic. Its like the white area was set into the red area, with a sealant or gasket in between, and that is where the water is coming in, because that is where it leaks out of. Maybe once as much of the water as possible is out, i will hit that with some clear silicone sealant or something.
The attached pictures show where it is leaking from, as well as the amount of water collecting at the bottom. Apologies for the bathroom photos, it was the best light without going back downstairs. /lazy
Attached Thumbnails Tail light condensation-20171202_220530.jpg   Tail light condensation-20171202_220219.jpg
Old 12-08-2017, 12:24 PM
Paulc732's Avatar
Old 12-08-2017, 02:50 PM
Originally Posted by Paulc732
You could try Putting the light in a bucket of Rice for a couple of days to dry it out...
i was joking around about doing that just not having enough rice to get the job done. It would be a pretty cheap solution though.
Old 03-07-2021, 08:26 AM
silvertonesx24's Avatar
I just noticed this in mine, same place, the same or a bit less amount of condensation. Thanks for the update, I may try something similar, or hitting it with a heat gun
Old 05-01-2021, 06:12 AM
Tomwhite's Avatar
After drying the rear light, will applying a clear protective film on it solve the problem?
Old 08-05-2021, 03:55 PM
dsd's Avatar
dsd
dsd is offline
Any update on a full solution? My passenger tail light has permanent condensation now. When I get a chance I will pull the light and dry it out, but any idea what to seal it with? Not having seen it myself, maybe a bead of silicon caulk?
Thanks!
Old 06-19-2023, 08:01 AM
danu99's Avatar
Thanks!
Why condensation? Except a crack? I don't have a crack and still condensationd
Old 05-10-2024, 12:48 PM
danu99's Avatar
Default condensation
hi guys.
it a almost summer and my condensation doesn't go away
so......couple of questions for you
is the clear part of the tail light a separate piece from the red part? if so, schematics? is there any way to dismantle the tail light? not remove from socket, discmantle if possible.
the black plastic part and the red and white part of the tail light, are glued? or heat pressed? or gasket?
i refuse to drill holes in it.
i will remove and dry the hell out of it.
i will use some really good bison adhesive , to seal everything on the back side. i used bison to repair parts of a headlight's broken mounts and its still holds after years. so.....why not to resigle the taillight?
i can and will ppf (protective film) the hell out of it.( done it on headlights and cars, wet and hot method)
did some of you did stuff like this? did it work? i really don't want to hear about drilling it , neighter front or back of it.
and finally.........you guys had moisture only on the transparent raised part......or in the red part also?
think the transparent part is inserted like in a socket , in the red part. if so.....that explaines why only transparent part is getting condensation.
so...please....ideas?
Old 05-10-2024, 01:01 PM
Vasara's Avatar
If you have accumulard water at botton: You have leak somewhere in lamp assembly.
Occosional moist is a dev effect caused by temperature differences and that is normal, because XJ rear light are closesd from factory and don´t breath moist out.
Many light assembly manufacturers use GORE valve stickers to reduct moist inside:
https://www.gore.com/products/gore-a...or-electronics
Cheap and easy to add as DIY.
Old 05-10-2024, 01:14 PM
danu99's Avatar
Only at the top. Like a mist and some drips. But if sealed…. Where is it coming from?
Being led and not bulb, should be pretty air tight. Gasket from the plug?
Still.… some ideas for the source of the moist?
I prefer to seal everything really good
Old 05-10-2024, 04:36 PM
Vasara's Avatar
Air trapped inside in factory had moist already, like any normal air.
Quick Reply: Tail light condensation
