Time to replace brake pads any recommendations
My recommendation is if you want to go to a non OEM brake pad you will need to replace both front and rear at the same time since the coefficient of friction needs to be the same. As I have said before in the forum. I used ceramic pads on my 2001 XJR and while they had significantly less brake dust they didn't stop as well as the OEM pads and rotors.
alanhodges (10-18-2017)
