Too much power for stock 275s! Anyone fit 305 tires on?
So my car is pushing quite a bit of power and stock 275/35/20 can't keep up , even spinining around 45 mph on dry pavement 😆. Latest modifications as pictured. Finished up prototyping and now final development for the intake system. Uses paper oem type of filtration, but it's double the size of the original volume plus velocity stack inside so flows more . Showing easy 15 horsepower gain so far Possible heat shield option as well but so far it's not an issue. Found a pair of 305/35/20 anyone fit such size on factory 20s?
__________________
2008 XKR Convertible, (mods: AlphaJagTuning ECU Tune , 1.5lb pulley, (200cel cats( are now melted), xpipe, Bosch 001 pump, 180 Thermostat.
Drag strip : 7.9sec 1/8mi 90 MPH . 1/4 mile 12.55 at 112.98mph
432rwh Dyno on Mustang Dynometer , Approx 511 crank HP.
2013 XJ 5.0 SC (Alpha Jag ECU, TCU tune, crank pulley), 600+ HP, 11.6 sec 1/4th mi 122mph, 7.6sec 1/8th mi
Well I'm answering my own question 305s fit just fine ! although I did go with 305 by 30 20 instead of by 35
__________________
