TPMS question for the Pro's
2013 XJL Portfolio with 59K miles on it. The TPMS displays a Tire Pressure System Fault. All 4 TPMS are OEM Continental and new. This version has the Space Saver w. no TPMS sensor. In SDD the car is programmed correctly for no spare. This nightmare started after replacing all tires about 6 months ago, no matter what I do, I can't get the light to stay off. If I just do a Hard Reset (battery disconnect) the diplay will show the "Check Spare Tire Pressure" light and eventually go into the TPMS System Fault...I tried to program each TPMS sensor in the module - this solution works only after programming each TPMS sensor and doing a Battery Hard Reset. Upon start-up, the TPMS warning is off, but after driving 20 minutes or so the warning comes back on - the TPMS light flashes then goes solid. I have accesss to SDD and Launch X431 DealerVersion. In Launch, I cannot spot an actual TPMS Module for diagnostics - it seems to be a part of the BCM? In the Factory repair manual, it shows the TPMS Module located under the front passenger seat - well, this car does NOT have a TPMS Module there. I visually checked the receiving antenna and each wheel sensor antennas - no issues. Does anyone know where the TPMS Module is located? I want to do a visual check on it. Other than that I am stumped - did anyone else experience this?
A few questions. Did you get the proper mHz sensors? I've had nothing but bad luck with non-OEM sensors. Jaguar only for me. There should be no signal for spare at all. I dont think it was available in the US for this MY. The antenna near the rearview mirror will tell you correct mHz.
The controlling software for the Tire Pressure Monitoring System (TPMS) is located within the CJB. The software detects the following:
The CJB communicates with the instrument cluster via the medium speed CAN bus to provide the driver with appropriate warnings. The CJB also indicates status or failure of the TPMS or components.
- When the tire pressure is below the recommended low pressure value - under inflated tire.
- The location of the tire on the vehicle that is below the recommended pressure.
- Malfunction warning.
- CJB located behind the rear seats.
- Tire pressure receiver is located above the roof concole.
- Two front initiators positioned forward of the wheels and behind the fender splash shields.
- Two rear initiators positioned rearward of the wheels and assembled on dedicated brackets located behind the fender splash shields.
- Four sensors, each sensor is integral with a tire valve and located within the tire; the space saver spare wheel is not fitted with a sensor.
The following 2 users liked this post by Rummy636:
Ken Dreger (07-10-2023),
kroache (01-24-2022)
Thank you for the quick reply, If I remember correctly the TPMS sensors were VDO/Continental SE52029 at 315 MHZ (which matches the receiving antenna frequency). I did find it odd that it was showing the "check spare tire pressure" that is why I checked the settings in the SDD. You have 2 choices when programming the new TPMS, sensors in the system. One is the Space Saver wheel and the other is the Spare tire (being the 5th TPMS...I programmed it correctly using the Space Saver option. Once I did a Hard Reset as well, all was well for 20 miles or some time. The light comes on again. I will visually check the CJB, I know there were some issues with other Jaguars and the CJB but I didn't think it would be the issue for this since it does program fine and responds to Special Functions in SDD and Launch. I figured if it fails it would fail completely.
No TPMS in my spare? 2014 XJR. I got 4 cheap Chinese ones off EBay and had Discount Tire check them with their tool before installation.
They were only $30 for a set of 4.
Can't explain your 20 mile and the light comes on either?
Any reason you used SDD? I just installed the new ones and drove until the light went out.
Just asking as I have an SDD but did not use it.
Were the sensors installed with the new tires 6 months ago? If so any help from the tire people?
I used the SDD because the TPMS light did not go out by itself. I know the system will "read" the senors by itself after several cycles/drive time. But mine didn't - and 5 months passed. Every now and again, I have a few days off and I try to play with it. I did try the cheaper "knockoff" 315 MHZ pre-programmes sensors at first - that didn't work either, so I went to to the OEM
I would go to your nearest Discount Tire and have them read the sensors. That should tell you real quick where the problem is.
Or is your Launch X431 telling you there is a problem?
See this thread as it points to you having more than one bad TPMS which I think is your problem.
TPMS Problems
TPMS Problems
![Post](https://www.jaguarforums.com/forum/images/icons/icon1.gif)
Please, just deflate the 4 tires to 10 PSI and turn on the instrument panel for a few seconds and turn off.
After that inflate the 4 tires with two or 4 PSI over normal and that is it.
I just did it yesterday and until now all 4 lights are gone.
You will not lose anything just try it.
Ken Dreger (02-11-2022)
I'm so sorry that I did not take a picture before I did what I already wrote yesterday.
Today I drive my Xj 2013 that had 4 TMPS lights on but I did what was mentioned below and all four lights went and did not light again.
Remember that each tire has its own sensor that looks like AN ELBOW AND WORK AS A HEIGHT SENSOR when you raise your car gets imbalanced that is why you should lower the car.
Front Suspension Height Sensor.
After deflating all 4 tires to 0 psi do not inflate the tire with the engine on.
After deflating just leave the car off for a longer time and then proceed to inflate.
It worked with my car.
I just want to help.
Please, excuse my bad English
Thank you
Thank you
TPMS issues can be a real pain. If problems persist, it may require a dealership visit.
If you haven’t already, read this F-type thread for inspiration:
https://www.jaguarforums.com/forum/f...2/tpms-162046/
Clamdigger
09-09-2014 07:23 AM
