XJ ( X351 ) 2009 - 2019
Transmission Fluid
Old 08-09-2022, 10:49 AM
Shadow Cat's Avatar
Default Transmission Fluid
Good morning all,
I am trying to find out what type of transmission fluid does my Jag take.
Can anyone help?
​​​2011 XJL 5.0 non S/C
Old 08-09-2022, 12:22 PM
clubairth1's Avatar
Received 2,408 Likes on 1,894 Posts
You have the 6 speed so you are in luck because you can use the very common Mercon SP in place of the Lifeguard 6 fluid if you want.
Are you going to do it?
Do you have all your parts yet?
If not I have used these guys as I used the Lifeguard 6 back before we knew about the cheaper and easier to get Mercon product. Note the only difference is the fluid color.
ZF Transmission Parts
Old 08-09-2022, 01:18 PM
Shadow Cat's Avatar
I am getting my tranny swapped and I want to bring my own fluid. If I had a lift and TIME I would do it myself.
Jaguila
02-10-2014 04:57 PM
adreasx
03-10-2012 06:42 PM
iownme
07-12-2011 07:53 AM
ibateman
01-13-2009 09:49 PM
Wild Bill
10-12-2008 09:54 AM
Quick Reply: Transmission Fluid
