XJ ( X351 ) 2009 - 2019
Trouble code P0444
Old 08-25-2019 | 02:16 PM
haendless's Avatar
Default Trouble code P0444
My 2012 XJL Portfolio Trouble code P0444 won’t go away replaced purge valve canister,evap leak detection pump,gas cap all as apart of different EVAP Codes... When code cleared after stop and start code re appears mechanic suggest replacing canister charcoals next....suggestions?
Old 08-25-2019 | 08:13 PM
Thermo's Avatar
haendless, looking up what triggers that code, I don't think replacing anything in the evap system is going to fix your problem. The code from what I can see is looking at electrical side of the purge valve and seeing if the circuit is intact. It is seeing either: 1) open wire in the loop, 2), the wiring is grounded to the body of the car, or 3) one of the wires has shorted to a 12V wire. This is where a simple multimeter should tell you if you have options 2 and 3 going on with the car by simply unplugging the evap solenoid and then measuring each of the pins. The open wire gets a little bit more troublesome unless you have a special tool (circuit tracer). With the circuit tracer, you input a signal on each of the wires and using the wand, you follow the wiring. The wand will beep at you as long as it still sees the signal. Where there is a break in the wiring, the signal stops, the beeping goes away.
I would say to also check the pins in the plug going to the evap valve. It may be possible that the pins have been bent a little bit and you are not getting a good electrical connection. If you don't mind a bit of a drive, I am south of you by an hour or so in California, MD. I am sure we can look at things and get it sorted out.
The following 2 users liked this post by Thermo:
haendless (08-26-2019), oldrover (09-12-2019)
Old 08-26-2019 | 01:25 AM
haendless's Avatar
Sure i have PMd you
Old 08-27-2019 | 11:02 AM
clubairth1's Avatar
Please post back your repair to help others if you can.
Wewillbfree
XJ40 ( XJ81 )
04-25-2017 07:22 AM
Poet
10-28-2015 07:25 AM
meeburtxk8
11-16-2012 03:29 PM
test point
09-29-2010 11:21 PM
morethansamson
07-02-2010 04:49 PM
Quick Reply: Trouble code P0444
