XJ ( X351 ) 2009 - 2019
Umm what’s this
Old 08-04-2024, 07:11 PM
Jlohojo7's Avatar
Default Umm what’s this
Found this in the engine valley when taking the supercharger off. I’ve not idea where it came from. See pic
Old 08-05-2024, 07:11 AM
Paldi's Avatar
Finger?
Old 08-05-2024, 08:57 AM
Jlohojo7's Avatar
Haha maybe the little part next to it but clever
Old 08-05-2024, 09:59 AM
Vasara's Avatar
There are an thread where this was questioned not long ago. If i remember right this part is sitting inside of waste gate actuator?
Old 08-05-2024, 10:42 AM
clubairth1's Avatar
Received 2,392 Likes on 1,887 Posts
It's used on the cars with an electric bypass valve. Jaguar calls it a "coupling". Part #C2D43581 about $30
SC Bypass Coupling
Circled in red below.
Don't lose it as you do need it!
Old 08-05-2024, 11:13 AM
lotusespritse's Avatar
Bingo
Old 08-05-2024, 11:19 AM
Jlohojo7's Avatar
Wow thank you so much. I never saw it fall out I just saw it sitting down there. What does it do and I wonder if it was there before and hasn’t been hooked up properly.
Old 08-05-2024, 11:25 AM
clubairth1's Avatar
Without it the actuator will operate but NOT turn the shaft on the bypass valve. So the bypass would not open "I think".
I am sure things would not be happy either!
Waste gates are on Turbo's. Bypass valve are on mechanical SC's.
Old 08-05-2024, 11:38 AM
Vasara's Avatar
Correct. Lost right words. (i did serious mind surfing for even waste gate term Total black out moment, only local language terms were in my mind: Bypass valve = Ohitus venttiili )
Old 08-05-2024, 11:41 AM
Jlohojo7's Avatar
Thank you very much gentlemen !
Old 08-05-2024, 11:48 AM
I knew what you meant.
Vasara (08-05-2024)
Old 08-05-2024, 12:50 PM
clubairth1's Avatar
So did I! Had to pull your chain a bit!
Vasara (08-05-2024)
orangeblossom
10-18-2022 04:45 AM
buckshot111
06-01-2021 08:00 PM
Stuart@VelocityAP
08-02-2018 07:51 PM
Delta66
Sights N Sounds
31
07-12-2014 10:39 AM
Michael Star
Photography
20
11-06-2013 08:06 AM
Quick Reply: Umm what’s this
