Upgrade from Supercharged to Supersport
Received 3,907 Likes
Bastiaan, why stop at 510 HP. From what I have read, you can get the smaller pulley through a place like Mina Gallery and then if you talk with your local dealership, they can put in the Supersport programming. That will take you to about 550 hp. Then, for a bit more, you can have a local dyno shop tweak the engine a little more and if the numbers are correct that others have said, you would be in the 620 hp range.
Hi Chris,
Thanks for your fast respons, anyway it isn't that I want to stop at 510Hp.
I really don't know if in my regio are dealers how are willing to do the reprogramming (first step)
And then smaller upper pulley (second step)
Does anyone know a reliable jaguar in the netherlands, mid germany or belgium?
One that I have HEARD a bit about is Arden, in Germany. Their web site is:
Arden - Jaguar, Range Rover, Bentley, MINI Startseite. You can contact Velocityap in Canada. Not sure if being a European car requires a different tune than North America or not, but the estimated power of the tune even without the pulley seems more than adequate.
EnosGl JagGate,
Thanks a lot for the info, currently i'm working that.
I had contact with Arden in Germany, actually they sent me a quote (quite) pricy without mentioning a power gain.
And a guarantee for that it will work.
For the moment i'm waiting for an answer from Applebee's engineering.
Keep you updated
regards
bas
Keep you updated
regards
bas
To all,
In Germany is also a dealer from veocityap.
www.jaguar-codierung.de
Just a 3hrs drive from where i live
VAP has a good reputation on this forum and I am running their tunes currently on my 2014 XJR with no complaints.
Just getting ready to install lower pulley and bigger inter-cooler and upgraded IC pump.
I also have their stage 2 tune for those additional mods.
You can't go wrong with VAP on Jaguars!
