XJ ( X351 ) 2009 - 2019
Upgrading the 2010/2011 slow touch screen display
Old 01-06-2019, 04:54 PM
Shaun Flowers's Avatar
Default Replacement not working
Thanks for that.
how do you know its from a range rover?
i will be looking for another one to buy. What should i be looking for? Apart from the date.
many thanks.
  #122
Old 01-06-2019, 06:42 PM
Received 4,454 Likes on 2,426 Posts
Because of the part number, the GK62 prefix is Range Rover Sport L494
XJ is xW93 prefix, look here https://www.jaguarforums.com/forum/x...3/#post1992064
Dual View you want either DW93-10E889-BF or DW93-10E889-BE
  #123
Old 01-07-2019, 12:50 AM
Yes i need a dual view screen. Thanks for your advise.
thats really helped me. Thanks
  #124
Old 01-07-2019, 02:58 AM
toxo's Avatar
I appreciate this is in the X351 forum and is centered specifically around XJs, but I guess there could be some similarity with the XF as many systems are similar. I have a MY2011 XFR which is a recent purchase and the touch screen is infuriatingly slow, and as has been mentioned edging towards dangerous. A bit of scouring eBay and google seems to show that there were 2 touch screen units for the X250, one made by Alpine and one that has Bosch logos on the back - the Bosch one looks similar to the unit you're working with here. I would guess that the one unit is for the lower spec stereo option (no subwoofers etc) and the other unit is for the better system. However it appears that while your units have engineering numbers starting A-F followed by W93 the XF units are labelled A-F followed by X93.
I intend to pop the unit out of my dash later on today to see a) which type of unit the car has and b) whether it's an AX, BX, CX etc. There is a breakers near me which has a 2012 Bosch type (CX93) for £70 which might be worth a punt.
  #125
Old 01-07-2019, 03:01 AM
toxo's Avatar
I intend to pop the unit out of my dash later on today to see a) which type of unit the car has and b) whether it's an AX, BX, CX etc. There is a breakers near me which has a 2014 Bosch type (CX93) for £70 which might be worth a punt.
Just realised I made a mistake in there - the XF units part numbers are X23 not X93! So BX23 is what I suspect I have in mine.
  #126
Old 01-07-2019, 03:19 AM
No, the system in the XF up to 2011MY is totally different to the 2012MY onward, totally different, nothing compatible.
  #127
Old 01-07-2019, 03:20 AM
toxo's Avatar
That's rather infuriating. Mine is a very early 2011 (in fact I just checked and the date of registration is 23/Dec/2010) if that makes a difference. If not I guess I will just have to live with it!! The noise more than makes up for it
  #128
Old 01-09-2019, 08:13 AM
xdave's Avatar
A non-dual view CW93-10E889-AB has just been listed on eBay for £130 ($170 US). Ships worldwide from the UK.
I'm not affiliated, but if you are waiting for a fully compatible screen to come up then that is one.
(edit - compatible with XJ X351, it is not for an XF)
Angus (01-10-2019)
  #129
Old 01-09-2019, 08:30 AM
christ's Avatar
Aaargh. So close!
If I fit that one to mine (dual view), am I right in that I will get all of the functionality in the back, the only difference is that the front seat passenger can't watch TV/DVD/VCR?
-- toying with the idea of going with that one until a dual view comes in ...
  #130
Old 01-09-2019, 11:47 AM
xdave's Avatar
I believe we have had one member fit a single view screen into a dual view car.
You should retain all features except the front passenger dual view as you have said. The dual view button would just do nothing.
On the other hand you do gain twice the resolution on the screen as half is not used for each seat.
  #131
Old 01-10-2019, 03:33 AM
christ's Avatar
So I rush off to click buy, but someone beat me to it. Next time I'm not waiting!
Thanks for the heads up, xDave!
  #132
Old 03-07-2019, 05:00 AM
christ's Avatar
For those still following this thread, another one (apparently dual view) has turned up on UK eBay:
https://www.ebay.co.uk/itm/Jaguar-XJ...EAAOSwy6hcgOVK
  #133
Old 03-15-2019, 11:11 AM
markstan's Avatar
hi
is it possible to upgrade the screen and add dab as my portfolio does not have it
  #134
Old 03-15-2019, 12:02 PM
xdave's Avatar
Hello,
Upgrading the touch screen is covered in this thread.
You can see how to retrofit DAB on this other thread: https://www.jaguarforums.com/forum/x...ystems-162263/
  #135
Old 03-15-2019, 02:03 PM
clubairth1's Avatar
Received 2,351 Likes on 1,851 Posts
When asking questions we REALLY need what car you are asking about!!
It does make a difference.
  #136
Old 03-16-2019, 10:02 AM
xdave's Avatar
Another one on eBay from Lithuania. Dual view. It is at the top range of the prices these normally go for, but I'll share anyway in case you want one and are happy to pay the price.
UK: https://www.ebay.co.uk/itm/143173515815
US: https://www.ebay.com/itm/143173515815
  #137
Old 03-25-2019, 01:22 PM
madman1133's Avatar
So the car I purchased had this upgrade done. However, it seems like some of the functionality was lost. I can't get to the seat massage functions and the parking sensors in the front dont work. Not sure what happened.
  #138
Old 03-26-2019, 05:30 AM
christ's Avatar
At a guess your AW93 was replaced by a DW93 not a CW93, as what you describe appears to be the symptoms that result from such an 'upgrade'.
  #139
Old 04-03-2019, 07:04 AM
christ's Avatar
For those of you to the left of the pond without dual view:
https://www.ebay.co.uk/itm/2010-2012...MAAOSw8ihck82U
  #140
Old 05-19-2019, 09:02 AM
Quick Reply: Upgrading the 2010/2011 slow touch screen display
