Upgrading to the 2016 rear bumber, camera issues
Hi, i just upgraded rear bumber to a 2016 model, it looks much better. All was plug and play. but after installing i noticed i cant make rear view camera work because sockets are different. Also reverse light dont work and number plate lighting. I think everything will be good when i will use old wiring. But how to make rear view camera work? is there any adapter? or anyone knows if its compatible ? I can in the worst case remove it, and put an old one, although it will require some cutting+glue as camera size, locations are different. any ideas?
