VelocityAP 200 Cell Sport Catalysts for XJ X351
SovietKitsch (03-11-2016)
Johncy2000 (03-11-2016)
Looking forward to seeing the numbers!
Johncy2000 (03-17-2016)
Bonus points for the lacrosse stick.
Johncy2000 (03-20-2016)
#30
Had my pair installed today via NYJagparts. As of now the only mod on the car, hopefully to be joined shortly by an exhaust and ECU tune. The sound at higher RPM's is intoxicating. Need more open road to fully try it out!
Last edited by SovietKitsch; 04-16-2016 at 06:21 PM. Reason: Forgot to credit NYJagparts
Johncy2000 (04-17-2016)
#31
2011 Jaguar XJ - Sport catalytic converter from VelocityAP - YouTube
If we can set you up with a tune that would be awesome, we have hand-held programmers that store multiple modified files:
Jaguar/Landrover Denso ECU 5.0 Supercharger Pulley + ECU Tune
__________________
Stuart Dickinson
Managing Director
VelocityAP Industries Ltd.
O: (1)250-485-5126
E: Stuart@VelocityAP.com
www.velocityap.com
![](https://www.jaguarforums.com/forum/signaturepics/sigpic147732_1.gif)
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#32
Sounds awesome, and thanks very much for your business!
As a side note, I got some CEL codes that popped up after a little ride today. A P219B as a current fault and a P219A as a pending fault. This was after 50ish miles after the cats were put on. my GF noted she smelled "exhaust" or some fumes, so I'll keep an eye on this and see if it comes up again, and if it does see if there's a leak or something somewhere.
#33
#34
Perhaps SovietKitsch can comment, but following your feedback we revised the bell-section on the end of the cat to allow more overlap so hopefully the install was a lot smoother.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#35
The codes that were popping was P219A, P219B, and P2096 which is a Post Catalyst fuel trim system too lean on bank 1.
I brought it back to the install shop who said the codes are due to the cats and there was nothing they found wrong with it, although I'll probably have it checked at a close friends shop in a few days.
I really don't want to go around popping this CEL every 50 miles, so I hope it goes away/relearns the new cats/my friend can find something the install shop didn't.
#36
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#37
#38
If it is on one side only, not both banks... plus Johncy's car didn't have this issue. Also they are not the normal codes you would see for actual lean codes. I've seen sport cats throw a variety of codes on cars, like cat efficiency, sensor response rate or temperature, but never these ones. Seems like air leak.
__________________
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
Stuart Dickinson
Managing Director
O: (1)250-485-5126
www.velocityap.com
#39
Some months ago Jag had an update for O2 sensor heat/timing and, according to my tech, has resulted in some codes being thrown on some XJs and that it was better to not have had the update. In my case, for some reason, my XJ won't take the update and we think that was a good thing. Just an observation as to, maybe, why Johncy had no issue and SovietKitch did get codes thrown.
#40
I too have been working with VelocityAP on Exhaust and Tune for my 2011 XF SC.
It's an absolute blast to drive with Stuart's full performance set up. Sport Cats, Mufflers, Pulley and Tune. We made 75 extra HP.
The P219A and P219B codes are "Engine Overspeed Condition - signal invalid"
you need to stay of off the throttle....Ha Ha .
